manual shift transfer case
sewardmark
Minnesota
Anyone having trouble getting into 4 high or shifting out, mine takes about a 100 pounds of pressure to activate, in gear idling, or rolling any speed foot off gas, it is a 2013 ram 2500 4 x4 hemi
Brakelate
South/Central Utah
That sounds strange. Mine snicks in and out while rolling quite easily.
A little effort when it is a little bound up like after spinning the rear tires and burying them, then going into 4WD. That takes a bit of a tug, but nothing like you are experiencing.
It does like to be rolling little bit though.
Has it done it since new?
Are the wheel / tires stock?
Are they inflated equally, or close to it?
Does it feel the same if the truck is in Park or Neutral and you try to push / pull the lever?
This is travelling in a straight line, correct?
Something is not right. It should not require that much force.
S
sewardmark
Minnesota
It feels like it is a frozen cable, 17 below zero today, going to wait for a warm shop and remove cable, it was shifting in and out with ease, have not crossed deep water, did a body lift kit, but worked fine until it got cold, its got to be bound up in cable, a litle heat and some lube, will see
