Ian_Olivas
- Oct 19, 2016
- 325
- 67
- Location
- San Antonio,Tx
- 2002
- 4.7L Magnum
Does anyone have a 3rd gen ram with manual trans and hemi? And how hard is an auto to manual trans swap?
I bought a hemi single cab about a month ago that's the one im considering to do the swap in. It's an 03It was an option on 2500's...depends on what vehicle you're trying swap in. Does it already have a hemi? Or are you considering doing this on your 4.7 truck?
Well I wanted to rebuild it with a 392 stroker kit so id have to do research on what trans would be best for it. What trans did the srt10 use? Is the bell housing bolt pattern the same? Cause that should be able to hold the extra power out put right?It's doable...the biggest PITA is the elex. All or mostly factory parts, depending on what transmission you wanna use.
Lol I know. Believe me I searched for months for an 05 but didn't find anything for a good price. Everyone wanted more than 5k for a beat to **** truck that was taken care of by what looked like apes, most didn't run either. Then I find one for 1800 it was dirty and didn't drive but all it needed was a rear end rebuild and a good vacuum and whipe downBwahaha...now you've really complicated things. Should've gotten an 05 or newer, or at least an 04 lol. You're gonna need all kinds of computer and harness changes, not only to integrate a manual trans but also to tune a 392 properly. Viper truck used T56 6sp, plenty strong enough. I don't know if the bolt pattern is the same but if it isn't there are plenty of places to get adapters.
Interesting I'll contact them thenConsidering the assist they gave Cleveland PAP converting LX's to stick shift, you might consult hotwireauto.com about a complete conversion harness (03-05 PCM with manual trans). They've already done a few 03-05 conversions, plus you could have them change the coil pack connectors if you wanted to convert to the later coil pack setup.
or just swap the Dana for the 9.25
My '06 2500 Hemi 5.7 4x4 is a manual and the clutch is easier to drive smooth than my Porsche. I have always liked driving a stick but always try to miss heavy stop and go traffic that is the norm in Houston. Acceleration sucks as does the gas mileage when pressing too hard on the vertical pedal on the right. I am not sure if it's the transmission gearing or what but acceleration is not a strong point in this truck. I have thought of getting an engine programmer but don't know if it will make much of a change. I just had my PCM go out at 43K miles and am somewhat leary about messing with the computer.
