nascar72
Hey guys thanks for letting me join the forum. I have an '03 Ram 1500 4x4 quad cab with 5.7 Hemi, 5-45RFE tranny and 3.55 gears. I'm towing a 24ft 5ft wheel camper RV that weighs around 7000 lbs cargo included. Been towing RVs for few years now and been doing it in 3rd gear (O/D off) everytime no matter what truck I was driving. So far so good. Now, I've been towing my RV camper mostly on hilly roads with quite some steep inclines and I've always wondered if I should manually downshift or go with throttle downshift? I've tried it once going uphill in 3rd and obviously loosing alot of momentum dropping from 65mph to 50mph at wich speed I decided to manually downshift in 2nd. Didn't like the feeling at all when it dropped in 2nd compared to when I kick it down with the throttle. So what would be the proper way to manually downshift and what would be the ideal speed to manually go from 3rd to 2nd or should I keep going with throttle downshift? And...when you manually put it in 2nd, witch 2nd does it grab? The "takeoff gear" or the "kickdown gear"? Thanks in advance for your feedback.
