manually select gears?
RAM-pagingMN
Alexandria, MN
so i was trying to use the + and - to set the transmission to 6 manually, and nothing worked? i did this driving and parked, no numbers showed up at the bottom of the screen next to PNRD. i have a 2017 2500 laramie with the 6.4 hemi. ive seen others do this or have read others doing this. something im missing or a sequence?
G. Mcpherson
Vancouver, Wa.
2023 Ram 2500 CC SB Tradesman
Try starting out in drive. Then press the - switch and it should go to 1st. Then press + to move up.
mtofell
You must start the process holding the "-" and then it should should lock into whatever gear you are currently in. Then, you can set the highest gear by toggling up or down. You have to hold the "-" for a second or two to get it to get it to register so be sure you're doing that.
MADDOG
Living in a Firepit
You do have to firmly press the button.
I start manually shifting by putting the truck in drive, then pressing (and holding) the - button. It goes to 1st gear, then I press the + button to put it in the gear I want it to hold. 0 - 25 in 2nd gear, 0 - 35 in 3rd, 0 - 45 in 4th, 0 - 55 in 5th, freeway cruising above 55 in 6th or Full Auto D.
RLM5150
Nebraska
Just to add what others have posted, you won't be able to "manually shift" per se. You can force it to downshift by pressing "-", but you cannot force it to upshift. Whatever gear you select will be the top gear if will use, but you are not in control of when it shift to that top gear.
Ratket
Arizona-
And to exit the mode press and hold the + side of the switch.
R
RAM-pagingMN
Alexandria, MN
thanks everyone for the replies. i used the search function after posting, of course, and found other helpful threads!
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
As 5150 stated it won't let you manually shift as what you might be used to. I thought it would be the same as the paddles on my Durango, but it doesn't work like that. Pretty much just a gear hold.
