dgroet
2011 Ram 1500 Laramie. 135k, have owned the truck 4 months
Lighting issue:
Map lights come on as they should when the car is unlocked and the doors are opened. However, they will not come on manually when you push them in. They have worked twice since I bought the truck.
Glove box light. Worked when I got the truck because I commented that it actually had a light, and that it worked. No longer works.
Underhood light. Same as above.
Thoughts??? Could it be the dreaded TIPM?? It was replaced 2 years ago (I got every service record from the previous owner)
Lighting issue:
