Maxtrac 1.5" leveling spacer?
2016Bighorny
Wisconsin
I would like a little bit of front end height adjustment... nothing crazy, just about 1.5" sounds perfect to me!
I have a 2016 1500 4x4 Crew Cab Big Horn. I just bought a set of lt275/65R20 Pirelli Scorpions a/t plus, and I just thought my truck would look a little nice with the front end up a hair.
I guess my question is, will I run into ANY issues with my oem upper control arms and ball joints, with only 1.5" spacers??
I do not have any desire to go any higher, so if these 1.5" spacers are a bad idea, I'll just be staying stock...
Thank you.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
I have a 2016 1400 4x4 Crew Cab Big Horn. I just bought a set of lt275/65R20 Pirelli Scorpions a/t plus, and I just thought my truck would look a little nice with the front end up a hair.
T
I don't think you would honestly since you are basically just leveling the front end ...which spacers are you going with, the aluminum or the forged ones ? I would suggest you go with these right here ...
2016Bighorny
2016Bighorny
Wisconsin
It appears those are for a 2wd application, mine is a 4wd...
I was looking at these:
Nick@GotExhaust
Preferred Vendor
SC
It is well documented here by many how bad spacers are for 4wd RAMs. I would recommend Bilstein 5100's as a low cost option to level/lift the front. If you want better ride comfort and performance off road we have many other options but the 5100's are a great budget option that will not cause any damage like spacers will.
message me if you would like a quote or more info
