- Jan 17, 2016
- 17,584
- 34,502
- 14 Sport
- 5.7
You can get rid of the trackbar relocation bracket if you want by relocating the hole on the frame side.I had this exact same issue recently, after doing the Belltech 2/4 kit.
I first replaced the rear shocks with the QA1 single adjustable shocks. When they were cranked to 12 out of 18 it was pretty manageable. The faster I got, the less it wobbled.
I did the torsion bar relocation kit from IHC and still had a bit of a wobble, though significantly less noticeable. It would start for a split second and correct itself just as fast as it started.
I had a loose bolt on the stabilization bar (the one that connects to the back of the axle) relocation bracket. It's the only vertical bolt on the bracket. I can't get a socket on it to torque it down because there's too much **** in the way. I cranked it down again, after finding it loose again, and it helped. I then had the bracket welded in place. That virtually eliminated it.
I have the single adjustable down at 7 out of 18 now and only feel a very slight wobble over really bad bumps.
I relocated both the diff bracket hole and the frame hole and got rid of the trackbar bracket.
You can also see how my earlier Illicit brackets relocate the lower arm.
