jcs64
- Nov 29, 2013
- 117
- 17
- Location
- amsterdam ny
- 2012 4wd
- hemi 5.7
Ok guys, help bail me out from taking a gamble
I bought the mcgaughys 2/4 kit (Model: 44050) for my '12 ram 4wd with hopes that the spindles would work w/ the 4 wd.
They do bolt up but it causes some BAD angles for the top ball joints!
So these spindles are basically new w/ no road time at all, they were just bolted on and then removed shortly after.
These spindles are the newest revision w/ the window cut for extra clearance for the lower ball joint. They also come w/ smaller nyloc nuts for the lower ball joint (I put one on and really didn't see the need for not using the stock ones, but the nylocs are included too)
as for years it fits, They were part of kit 44050 which fits '09-'12. Looking at pics, they may even be the same spindles that fit earlier years and '13, but ill leave that up to you to decide.
$390 + shipping
The box will be 15x15x9 and weigh 55 lbs so you can check out a shipping quote if you want from zip code 12010.
if your interested, pm me w/ your shipping address and ill get back to you w/ the best price I can do.
thanks, jeff
$390 + shipping
thanks, jeff
