MDS Solenoid
stock2016
New York
Will a bad MDS solenoid always set off the check engine light ?
Brandon-w
Yukon
2015 Ram 1500
Im not sure. Any intermittent mds codes? I'd think if a solenoid was going you'd get a code like: solenoid circuit high, low, or short to ground something like that. What kind of problems are you having that makes you think it's an mds solenoid?
Sent from my SM-A530W using Tapatalk
S
stock2016
New York
Intermittent roughness that goes away as soon as I deactivate the MDS on steering wheel
Brandon-w
Yukon
2015 Ram 1500
Could be mds you are disabling the mds on the wheel by using gear selector and dropping a gear? Also. Try it in tow haul mode. Im thinking it could be mds or possible torque converter, when torque converter is going sometimes you can tell because it will go into lock up and vibrate. But it usually only does this when in the highest gear and then goes into lockup.
Brandon-w
Yukon
2015 Ram 1500
Hey did you figure out what was going on yet?
