Meatmans 19' warlock
Meatman8769
Comox, bc
Added black sidesteps
Mopar cold air intake
Ram air hood vent
33 x 12 toyo open country rt tires
Sitting on 20 x 12 kmc wheels
Muffler swap and fox suspension on the way.
Wish list will be headers and bigger exhaust tips in black and possibly rock guard or black wrap on the lower half of the truck.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Looks good !!! Like the blue and black together looks B@D@$$ ...
Are you planning on going with bigger lift kit later on?
And I would suggest you spray the lower half of the truck with raptor bedliner which you could do yourself if you want to wrap it black , that will help against rock chips and would look B@D@$$ , I have been thinking about doing it to mine but just haven't had the time to do so ..
Either way it looks good !
Meatman8769
Meatman8769
Comox, bc
Thanks man. Ya thats what I've been leaning towards. Got a good polish on her a month ago and notice some savage rock chips. That was to be expected though having offsets and no mud flaps. Rather this look. Got a good local shop for bedliners so will see what they say. If they don't do the sides I'll do my self. Would definitely be great protection
2018 2wd
Not hard to do at all yourself, the kit itself is less than $100 USA and you really would only need 1 quart of it but I would spray it with 2 quarts for a thicker layer
crazykid1994
I sprayed just the bottom and inside of the rocker panels with bedliner. Used a rattle can from Home Depot. Like 3 or 4 coats of spray after using a Soft brillo pad to get some scuffs in the paint. It’s a bit hard to see in the picture but I used the lower line if the body as my edge for the bedliner. I think there’s more pics in my build thread. Also built home made rocker guards/side steps that are also door ding protectors. I was going to spray the whole rocker panel but figured my steps are good enough and eventually I’ll make true full wheel to wheel rock sliders.
2018 2wd
It gave it an extra 2" of height lol ...
Meatman8769
Meatman8769
Comox, bc
Looks good! I may go a little higher but don't wanna cover up too much of the nice patriot blue color
crazykid1994
Originally I was going to use the body line right at the bottom of the door but was t entirely sure so went lower since the rest is protected by my steps
Meatman8769
Meatman8769
Comox, bc
That's what I'm thinking is the body line at the door. Ya your steps look like they cover much more than mine. Which ones are yours?
crazykid1994
Custom. I made them in my garage.
Meatman8769
Meatman8769
Comox, bc
So here we have my hood vent ram air which will sit on top of my already installed Cai. Which looks like.it could use a cleaning haha. So don't mind that.
As well we have the matte black wrap that came in for my front emblem. It doesn't cover the entire grey letters like I was hoping but turned out great and looks decent with a black middle and silver outline.
Also installed the Mishimoto oil catch can but forgot to take a pic of that.
Meatman8769
Meatman8769
Comox, bc
Long weekend here in
Meatman8769
Meatman8769
Comox, bc
Magnaflow muffler installed. Rear fox shocks installed and waiting for the other front to come in then the shocks will be complete!
Meatman8769
Meatman8769
Comox, bc
Cleaned things up a bit this weekend. Can see the catch can up front now
Meatman8769
Meatman8769
Comox, bc
So in the last little bit since getting the mishimoto oils catch can. I've also added the Fox 2.0 performance shocks all around, man is it ever smooth. May need to add an 2"lift in the front to level it out again. Feel like the rough country 1" isn't doing much anymore and I'm still getting some rubbing with my 33s and -44 offset. only at full crank.
If it wasn't mentioned earlier in this thread the magnaflow direct fit muffler was installed and sounds amazing. Has a really nice rumble and isn't abnoxiously loud. Will keep it on until I do the borla touring catback next year.
Also trying out the diablo pulsar right now. Has some cool settings for saving gas or if you want to ramp the performance up a knotch. Will run this a bit until I need to get an actual tune done.
Right now the trucks running and feeling like a dream
