missfiring
joshua1998
5.2 V8
Hi my nsme is joshua i have a 98 dodge ram 1500 with a 5.2 318 i having missfire once in a while i did all the plug an wires an cap an rotar
Check an change the uper gasket
An still having a missfire tried doing a fuel pressure check an i have between 45 an 49 psi any advice please
auskip07
s
s
sure you got the plug wires in the correct spot on the rotor?
Yeret
Professional Procrastinator
Behind a computer saying, "looks easy enough..."
5.9 Magnum
If he switched a pair of wires, he'd have a hell of a lot more than an "occasional" misfire, LOL.
If they're all wrong, the engine won't even start. Ask me how I know, LOL.
Got any codes?
joshua1998
joshua1998
5.2 V8
For some reason my truck won't show what codes are poping
joshua1998
joshua1998
5.2 V8
No all the wires are i n the correct spot
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Check the number 8 or 7 spark plug and pull number 1 or 2 for comparison. If 7 or 8 are a lot more fouled than 1 or 2, compression test it. You changed the plenum gasket?
joshua1998
joshua1998
5.2 V8
I change the plenum the intake manifold an throttle body gasket last week did new plugs a n wires an cap an rotar three weeks ago
dudeman2009
Magnum 360
Ok, we at least you got the plenum out of the way. Short of doing a compression test on the cylinders, i'd be a little slow on figuring out where to go next.
82Crew
North of St. Louis
318 Magnum, 6.7 Cummins
If you did the plugs before the intake gaskets it may have fouled one. I would pull them and make sure they all look good
dapepper9
Iowa/Nebraska Border
5.9L V8
Double check wire routing. Crossing wires can lead to cross talk and misfires. Also what kind of plugs did you use?
