Missing coolant
Sterling
2001 offroad
Magnum 5.9
I'm losing coolant. No drips or signs of a leak.
I feared a head gasket so I bought a chemical test kit and got nothing. I can smell coolant so I'm guessing the heater core? If it leaks where would I see it? Or would I see it? If I use a pressure test would that test the entire cooling system or just the radiator?
When I purchased the 5.9 a month ago it had no heat so I cleaned the heater core. Filthy swamp water came out.
Thanks
Joe w.
Virginia
318 5.2l
I never saw a leak when my heater core went out
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
I'm going to bet on the heater core. Unless coolant is gushing under the hood, the only way to smell it is if its coming from the vents. If its a small enough leak, you won't have any real puddles as it will evaporate as fast as it leaks. Its been my experience that when you flush the radiator, if it looks like crap, you probably just washed away garbage that was plugging a hole.
I made a couple posts on here about how to replace the heater core without disconnecting the AC or pulling the whole dash.
Reactions: Mop
S
Sterling
2001 offroad
Magnum 5.9
Thanks. Guess I'll shunt off the heater core and freeze my a** off until I get it replaced. Before I freeze what is the best method to test?
dudeman2009
Magnum 360
You're using coolant, you can smell it and its not gushing under the hood, that kind of test enough.
Butt if you really want, you can get some UV dye and put it in the radiator, run around for a few days, then use a black light and check around your vents. The windshield too if you use the defrost setting a lot.
S
Sterling
2001 offroad
Magnum 5.9
Yeah, I guess you're right. It certainly sounds like the heater core. Guess I'll be looking at your heater core post.
Thanks
dondale13
fancied up 318 (5.2lt)
Sounds like a heater core. Make sure the radiator's full, drive til the truck is hot, close the windows, turn on the defrost. If it definitely is the heater core you'll get a much stronger smell, if it's a really bad leak your windshield will fog over! If it ain't your heater core hit us back, a lot of experience on here!
alanack6795
5.9L6
The evaporator box has a drain near the passenger side manifold. It will **** coolant on the ground if the heater core goes.
Drop the blow motor and stick your finger in there
