MMX Cam Swap - Tune Question
ramnododge
Charlotte NC
Hi guys. I'm finished with my Cam swap after some lifter failure / cam failure on my 2013 Ram 1500 5.7 Hemi, and got everything back together. Ready to fire it up this weekend to test everything, but took a pause on the tuner side of things. I *think* i may have made a mistake with my order from MMX, and didn't catch it until now. So what I got from them is:
- *RECOMMEND - Please Include a Full Set of Hellcat Lifters and MDS Plugs With My Order
- 5.7/6.4 2009+ Camshaft (VVT) "RAM ONLY"
- New Mopar VVT Camshaft Bolt
- Timing Set (Partial)
- Diablosport Predator 2 for 2009-2014 ONLY Dodge Ram Trucks - RAM 1500 ONLY!
So here's where I'm wondering that I messed up. I THOUGHT I got a camshaft that didn't require tuning, but looking at their website, they've got their own camshaft that says "No Tuning required"....but of course that's not what I got. AND to top that off, I did not get a phaser limiter, bc I was thinking I don't need one. I did receive a Diablosport tuner, though, knowing I needed that to turn off MDS.
So since its the weekend, and I really wanted to get the truck running, I can't ask MMX. Those of you familiar with MMX cam swap, do I need some sort of tune (other than turning off MDS) for this particular Camshaft? And even worse....do I need a phaser limiter installed too?
Thanks guys!
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Need more info on the cam
Can you not go to MMX web & see which cam you got along with the phaser lock required?
If it list the option to buy limiter/lock it's required.
R
ramnododge
Charlotte NC
Yes unfortunately I don't have anything more from MMX. It was the build your own kit for the MDS delete, so I'm sure I made some wrong clicks. The box for the Camshaft has the p/n as 53022314AD, with its origination address from a Dodge dealer, so it looks to be the Non-MDS Mopar camshaft, if that answers anything.
To your point, if limiter was offered; on the website it DOES let you go with Partial or Full timing kit. Of course I went with partial, which does not include the limiter. However, there was no disclaimer saying that it was needed if you choose the "5.7/6.4 2009+ Camshaft (VVT) "RAM ONLY"" camshaft. But it certainly was an option.
https://www.modernmusclextreme.com/...delete-kit-by-mmxmopar-components-listed.aspx
crackerjack1957
There are no options for limiter or lock on that link.
Click on info beside options
I do believe you are good for that cam without limiter/lock
As far as tune required, not 100% sure but the way they word it in the description at the bottom......it just needs mds tuned out
Should verify with MMX for sure!!!
Sillygoose
looks like you got a stock replacement non-mds cam, so you should be good to go with what you have. use the diablow to turn off mds.
R
ramnododge
Charlotte NC
Not trying to thread jack here, But why did you go with the MMX kit instead of something else? I was looking at this.
https://www.amsracing.net/collectio...pcm-swap-for-2015-ram-5-7l-hemi-truck-engines
No particular reason. I spent so much time looking at all the options. I originally pieced together everything from mopar to do it, but ended up returning it bc I thought the tick was going away (it was not).
A lot of people on this forum are fans of mmx so I went with them on a whim essentially bc I just needed to pick something and roll with it. Admittedly, I’m a not in the camp that MDS has anything at all to do with the tick. But the non-mds package was cheaper.
I’m not huge with wanting performance on this truck. I’ve got a scat challenger so all my fun comes from that. I just need this truck to run, and that’s it. So to answer your question, no reason bc I don’t really know much about the differences anyways.
R
ramnododge
Charlotte NC
You were correct! And MMX confirmed it.
Plugged diablosport in to turn off MDS and the tuner failed and bricked my truck :( so now Diablo has my entire PCM to get it back to working
Sillygoose
Diablow has been iffy since they began supporting dcx applications. An SCT tuner (w/ a pre-loaded comp 268 cam tune) saved me when mine bricked.
