Module location for back up sensors?
Alex_cad
3.0 eco diesel
Hi guys.
Does anybody know where this module is located?
I'm working on adding oem parking sensors to my 2015 ram 1500SLT and everything is on accept the module.
WilliamS
Tampa FL
Im 73 percent certain its above the driver kick panel.
Alex_cad
Alex_cad
3.0 eco diesel
I believe there was a topic or thread at this forum like some one has added front and rear sensors and also was going to do a push button start and keyless entry thing. Can't find it though.
DeereGuy
Preferred Vendor
Pittsburgh, PA
Yep remove the driver side kick panel and that’s where it should be. I changed mine when I hooked my front park sense up.
Alex_cad
Alex_cad
3.0 eco diesel
Tnx for the reply,
How difficult it was to do front sensors?
DeereGuy
Preferred Vendor
Pittsburgh, PA
Be forewarned if you are going to try and enable the setting in the BCM with the AE tool. I tried it and it did some weird things including turning the power fold headrest option on the radio and removing my cargo cam button and it still never correctly activated the sensors.
DeereGuy
Preferred Vendor
Pittsburgh, PA
Tnx for the reply,
I got lucky I had all of the wiring in place since I had rear parksense from the factory. I just replaced my whole front bumper with one that had the sensors in it.The fronts work correctly but won’t show in the EVIC correctly. Couldn’t turn the feature on with AE, so I just use it as is.
Alex_cad
Alex_cad
3.0 eco diesel
Mine was activated by the dealer. The only thing they didn't want to do was heated/vented seats.
skuppy069
canada alberta
2018 1500 cc
I am considering doing this upgrade as well .
Did you have to add any wiring to your truck ?
Thanks .
skuppy069
canada alberta
2018 1500 cc
How does one know if the wiring is in place on there truck ?
I have a green connector that is in the spot where I think the module would go .
Thanks for any help in advance.
Alex_cad
Alex_cad
3.0 eco diesel
Thanks .
I'm in the process of finding out if I do need to add some wiring.
But I had the plug at the tail gate area for sensors, so I hope I have another end somewhere under the dash. But no luck yet.
I have a complete harness from the limited truck, And I'm cannibalising it time to time. So I hope to pull out needed wiring from it and add to my truck, basically the same way as I did to my heated/cooled seats.
It would be great if some one could take a picture where it's located.
Alex_cad
Alex_cad
3.0 eco diesel
Since I cant find another end of my parking sensors under the steering wheel, I'm going to do create it. In case I'm successful and everything works I will post it in DIY.
Fingers crossed.
