Stuffpower
Thinking of adding one. Is there any difference between these two companies? Is this upgrade worth it?
I’ve read mixed results.
Do you have a link for the elite hemi performance throttle body?Had a moes and now have an elite hemi performance on my 2017 5.7 (The 6.4 and 5.7 share the same throttle body). Both are ported very well. Not sure on the mmx. Just make sure the mmx is a ported and not a true bore unless you have a full bolt on engine to require that amount of airflow. A ported throttle body greatly helps airflow throughout the part throttle range and a tad bit at full throttle.
He is only on Facebook. You have to look him up and send him a message.Do you have a link for the elite hemi performance throttle body?
Ok, thanks. I don't use FB.He is only on Facebook. You have to look him up and send him a message.
I would just order moes if I was you. Keep the business in small businessTell me guys. Who’s do I order. I want to get this done already
No it should be just fine but an 87mm will do me just as good because mine is supercharged. The restrictions in the intake limit how much air can go in anyway. So 87 or 95 is gonna be the same result.Why did the 95 not really do anything or just doesn’t fit well?
take it it a machine shopI bought a 95mm kinda wish I would have gotten a 87mm. Or figure out how to take my extra stock TB apart and have it bored.
