Mopar 2" lift with a leveling kit?
AnthonyD1978
N. Arizona
2019 Power Wagon
Anyone running this setup?
I like my Mopar 2" lift and warranty, but was thinking of adding a leveling kit in the future. Will the Mopar control arms that come with the lift support a leveling kit too? Or is it too much?
DRkNESS
South Jersey
That’s a good question and one that I’ll be looking forward to seeing a response. Outside of the level kit, how are you liking the Mopar kit ?
AnthonyD1978
AnthonyD1978
N. Arizona
2019 Power Wagon
Loving it. Perfect height for me (level is not a huge priority). If I were to do it again I would have gone with a 35" tire instead of the 34". My lift and wheel combo should fit a 35" tire no problem. Had to turn around at parking garage once already :)
JB1
Houston, Texas
Adding a top spacer to the lifted struts is not recommended but I have seen a few people here do it on their 4th gens. If you kept it to a 1” lift spacer you would probably be ok. The issue isn’t the control arms but more the CV and steering angles past 3” level
Alx5737
California
Check out Lancaster ram. They sell some ram 1500's w 2" Mopar lift and a 1" leveling kit. Looks awesome.
California
HEMI 5.7
do you have pix of your truck with the lift kit? thanks!
AnthonyD1978
AnthonyD1978
N. Arizona
2019 Power Wagon
SnEg
New York
5.7 - Liter V8 HEMI® MDS VVT Engine
Would you able to tell me how high is your truck with this kit?
Alx5737
California
I ended up just adding the ORP spings to the mopar lift. It leveled out the truck and also compensated for the additional weight I've added to the truck. ~500 lbs worth.
After I added the springs:
View media item 28662
Before I added the springs:
View media item 28647
Hello, I had the older Mopar 2" lift kit with the spacer added along with ORP springs. I only did springs on the front did u do rear also? My front and rear are currently .5 " diffrence. Truck looks close to level.
