Ok perfect! I will be looking into them further now. I think i prefer the look of the alpharex over the dtmoto. Any concerns with the alpharex that you have?
Thanks again
No problem
I made this image to compare the adapter harness that TRS sells to swap your Quad/Dual headlights for the OEM Projectors, and the adapter harness that the DTmoto headlights comes with. As you can see, they are almost identical.
Here are images showing the similarities between the back of the OEM Ram Projector Headlight Housing and the back of the DTMoto Headlight Housing. Again, you can see the dust cover is identical, the main plug is identical, almost an exact copy.
13+ OEM Ram Headlight Housing
If these DTmoto headlights were made to fit ONLY the Quad/Dual Ram trucks, then they would have made them from the factory with the Quad/Dual OEM H13 plug and not the 13+ Projector plug, and then waste even more money having to build and include an adapter harness that could be completly avoided if these lights were just for Quad/Dual trucks.
My guess is the ebay sellers are not familiar with the Ram headlights and therefore they are just going off of the adapter harness that is included because it states that the adapter is for the Quad/Dual trucks so im guessing the sellers dont know that if you have a oem projector truck you can just skip that adapter harness and it will work for your truck.
As for the Alpha lights I bought, I love them. Im actually getting ready to open them up next week to install some custom RGBWA switchback boards in the upper and lower DRL spots, aswell as retrofit some real projectors into the low/high beam areas. I will also be painting them with a little bit of color-matched PR4 Flame Red, but only a few small accent spots, as i have the gloss black housings and i like the finish on them currently. I just dont like the chrome projector shroud.
Also i am having custom clear corners 3d printed for me, so i will most likely be the first person with the Alpha Rex lights with clear corner markers installed.
