I found an old android tablet so I’m just going to go that route and program the truck. Do I just need to set the LED low beams, LED high beams and Drl to yes?
You actually leave the low beam setting and the high beam setting alone. You’ll enable high intensity discharge headlamps under vehicle config 3. This is the setting that actually disables the pulse width modulation. The LED low beam setting doesn’t do anything when it’s set (according to an oscilloscope), and the high beams don’t need to be set to led because that circuit doesn’t use PWM.
These are the settings to activate the DRLs ONLY IF your truck came factory with projectors:
DRL configuration >optional
DRL lamp location > dedicated
DRL dropout enabled > yes
CBC I/O right dedicated DRL lamp output present> yes (should be yes already)
CBC I/O left dedicated DRL lamp output present > yes (should be yes already)
LED dedicated DRL present> yes
ECUConfig 3 DRL customer setting enable> yes
CustSetMenu 1 daytime running lights CSM> yes
