MoS2 versus Lubegard Biotech & Redline/QSUD
tantore
texas
just asking will lubegard help with the lifter and cam issues ?
Burla
Burla
2010 Hemi Reg Cab 4x4
It is very possible. great price too.
U&A
2016 3500 SRW
6.4 HEMI
Oh ****, here comes the boom :)
Good thing our engine swill mix it up to prevent fallout.
To be fair MOS2 never goes “into suspension” I think the molecules are too large for the oil to hold them.
I’m still a believer in MOS2 but I completely understand its downfalls
Sent while firmly grasping my redline lubed RAM [emoji231]
Burla
Burla
yeah, change the oil warm I doubt there would be an issue, but as you can see it does exactly what we thought it does. I have no idea how that would be safe for a di turbo.
U&A
2016 3500 SRW
6.4 HEMI
Very good point.
DI turbo and MOS2 do not mix.
I also think adding it to EVERY oil change may be a bad idea too.
Blstrick55
Everywhere
For those of you using Lubegard are you doing the 3oz per qt of oil ratio they recommend?
Burla
Burla
I think it depends on what oil you are using. I wouldn't recommend this with redline, and some oils have more moly then others. A low or no moly oil I would do 15 ounces, a good moly oil like qsud-amsoil-t&g I would just dump a 10 ounce size in there. The only time I would recommend biotech with redline would be if redline didn't kill a tick. If you are fighting start up chatter or tick, 15 ounces for sure any non redline oil.
Jtblackram
Long Island
My oil change is due in 400 miles, just got the lubeguard, gonna see if it makes any noticeable difference
tantore
texas
so using 15.oz.lubegard with 6.5qts.5w30 red line is a over kill ? at every oil change just wandering
Burla
Burla
I don't like the strategy of mixing esters. Redline is about as stout as you can get, unless you had a nagging tick I wouldn't even think about adding lubegard to redline. I'd probably opt for a different oil and use the lubegard, which is a legit strategy.
tantore
texas
(thanks burla for your answer)
