Can't go wrong with Zone.
No, they're factory offset/lenght. When you add 2-3" spacers to the top of your struts, UCA's are not the only thing you need to worry about. 2-3" top spacers are not a good thing. See if the visuals can help you and others like you reading this stuff. 1/2" top spacers are ok. 2-3" are not. you're overextending components that were not designed to move down that much.Will the mevotech ttx ucas work?
Did you have to do anything with your struts/shocks/springs up front/rear? I'm also considering doing the same. Price wise it works for me as my truck is "pavement princess" so I 99% of the time it never leaves the pavement. Was a wheel alignment needed afterwards? Thanks......I used RC when I ran the motofab worked good
Sent from my KYOCERA-E6920 using Tapatalk
Stock struts up front and springs/shocks rear. I added the Mevotech ttx UCAs. Got an alignment. Have had no issues. Rides fine. Tows fine. No off-roading though.Did you have to do anything with your struts/shocks/springs up front/rear? I'm also considering doing the same. Price wise it works for me as my truck is "pavement princess" so I 99% of the time it never leaves the pavement. Was a wheel alignment needed afterwards? Thanks......
