motor problem
Jorge Del Valle
Puerto Rico
Hi
I have a 1500 2019 classic v8- 5.7 hemi has 11,000 miles and suddenly after filling gas ist beggins to make sound on motor when I accelerate then loose power and black smoke from exhaust . This can be for bad gasoline or the fuel sensor not working
fireflymedic
Fla.
V6
Didn't get confused and put diesel in it did you. It would be interesting to go right back to same fuel pump and pump some in a can for close inspection.
tron67j
Maryland
If you are unsure if you accidentally put diesel fuel in (green handle at pump) do not drive this. Agree with above, take different vehicle back to station and see what you used. If not mistaken fill up of diesel fuel problem, you may have a bad injector. Are you getting error code? Either way, get this towed to a dealer ASAP.
