Muffler Mod time
LB3711
LB3711
Trumbull, CT
3.6L V6
lol yeah so. People see it everyday
No woo woo lol
LB3711
LB3711
Trumbull, CT
3.6L V6
Bringing my mod back up for some questions.
Does anyone with the Mufflex kits have issues with the 3" clamp at the front of the muffler not holding?
I got mine absolutely as tight as I can get it and its still loose enough that over time it slips out. Also it leaks out of that one and the 2 2.5" clamps on the otherside. Water drips out of all 3.
Should I just get it welded or get the stupid U clamps or find better Band clamps? Where could I find better band clamps?
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
Prolly be cheaper to get them welded than it would to buy new clamps. I don't have a problem with mine leaking or coming loose, neither does my buddy King. Have you just tried reseating the clamps and pipes, maybe something wasn't aligned right?
LB3711
LB3711
Trumbull, CT
3.6L V6
it was pushed all the way to the pin on the pipe on all 3 fittings. Everything was pushed to the front of the truck before tightened. I've been moving the 3" clamp to all different positions and the pipes still separate. I did my oil change yesterday and i went to check it and it was almost separated.
Trupiano
Registered User
6.7L CTD
Damn, that's ******! I guess I would say just get it welded then. Wont come loose or leak then. I welded my last trucks exhaust. From the rear tips all the way to the headers. Never had a leak or a problem.
LB3711
LB3711
Trumbull, CT
3.6L V6
yeah. I don't think I'll ever go back to stock. I hope it will last as long as I have the truck.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
you can try some high temp silicone on it? I think that is what Morgan did on his - mine leaked too........until I sold it and put the stocker back on.
LB3711
LB3711
Trumbull, CT
3.6L V6
hmm..
why you sell yours? Like stock better? I think its soo much better than stock garbage can muffler lol
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
I went from a delete pipe to a cutout. :D
THEBAD1
2003 Sport SLT QC2WD
this is the resonator. its under the shield there. Its not going to really make any difference
Keep thinking that....if you take it off it will sound BETTER!:superhack:
LB3711
LB3711
Trumbull, CT
3.6L V6
ahh ok lol
well before i go permanent i found in advance auto they had a little different but was still band style. I was able to tighten it really tight and seems to be holding in place. All 3 do leak water still but the pipes are not moving....for now.
xpst500
CA
2011 4X4 QC SB BIG HORN
welcome to the mufflex kit club.:party36: Only way to get this right is to have it welded.
LB3711
LB3711
Trumbull, CT
3.6L V6
Lol thanks. I'll see how it goes. If it separates again. It's getting welded and it's done with lol
Sent from my AT&T iPhone 4.
VLG6963
