Ole Buck
I am in the process of tearing down my tired 4.7 that puffs white smoke more than the local mosquito truck. This is my first endeavor on something this big. I will say that on this truck 04 1500 SLT 4x4 quad cab that Dodge made engine access really user friendly. Remove the front bumper the upper core support and the radiator and you can dang near walk straight into the engine bay. If all goes as planned this will be a nightly project with pics loaded and posted the next day. If there is anything that you see that could or should be done different let ya brother know. My goal is to show the disassembly the machine work on the heads and block and the reassembly with all new everything including but not limited to all sensors, water pump alternator oil pump plugs coils injectors belt hoses clamps radiator thermostat rad cap and any other thing that can be bought new will go in. I was able to snag a pair of HO cams and an HO intake. New pistons rings rockers valves valve springs lifters all bearings gaskets seals polished crank wrist pins freeze plugs ground straps. Its not going to happen overnight but I'm not going to drag around with it. I thought about a long block purchase but i just could not do it. This way there will be no guess work i will learn both good and bad and if it tears up its on me no trying to deal with warranty completely across the country. I have most of my parts already purchased just need to do the grunt work right now. My spare room in the house looks like a Summit racing warehouse with all the parts. Being in southern Bama humidity along with hurricanes is our worst enemy. The humidity here could make dirt get surface rust overnight. I will shut up now.
Here we go
the third pic down is the bottom radiator hose that i had to cut off. the gold stuff is the stop leak that the previous owner poured in.
Here we go
