my temp system
Marx
Southeastern Ontario Canada
Hemi 5.7L, 345 ci MDS
so i just couldn't go anylonger with out some bass so i wired up my amp cap and woffer. the wofferbox from my car is just sitting on the seat now.
can't wait till i make my center console
this is just a temporary fix
also did the seat mod
ramhunter9
P-Star Jeep Wrangler
looks good to me . what is a bass cap and what does it do ?
Hemiguy0302
Edmonton Alberta Canada
6.2 Boss
It temporarily stores power like a battery giving the amp smooth clean power and as an added bonus when the sub pounds it will not dim the lights on the truck as much as it normally would.
ramhunter9
ahh thanks man .
Marx
Marx
ya i don't get any dim i have a 1.5 farad cap on a 600w amp, witch is way over kill. Usually 1 farad for 1000W's of power
the cap also has a read out so i can see the voltage
AWE Daniel
Banned
If you are using big enough wire there should be no dim. I have none on my 800W amp with my 12
Marx
Marx
yes wire is important but it also depends on your battery size, alternator size, number of accessories on etc. if you are stock (meaning not running dual battery's or larger an stock battery), try turning everything on in your truck and crank your bass i bet you will dim,
also is your amp 800 rms or peak? it makes a huge difference
mine is 600w rms
and you battery can not discharge as fast as a capacitor during heavy bass
give this a read its good stuff
http://www.caraudiohelp.com/newsletter/car_audio_capacitor_myth.htm
AWE Daniel
Banned
mine is 600w rms
No its not quite as high RMS, but I have an optima yellow top and 6month old alternator. I use my bass with my headlights and driving lights on and it NEVER dims. I have heard many mixed opinions on the use-fullness of caps but im not gonna get into that.
Im still trying to figure out how much bass everyone needs to have, I have one 12 and never need to crank it to max lol
Marx
Marx
can't argue with personnel experiences lol
ya my 1 12 does me pretty good.
i guess i'm comparing it to my old car, it really dimmed until i put the cap on, i just transferred that system to my truck, i like to think it helps. If anything it stabilize the signal abit lol
Ram Man
FL
2013 Sport
All my gauges use to dim really bad when the bass would hit and the headlights on. But it was just the 3 year old battery and corroded terminal, got a new battery and new terminals and everything is dim free :)
shaunnz
