My Truck, it has a name.
B Mitty
Halifax
2021 Power Wagon 75th
6.4L
Black Betty - RAM JAM tuning it up to play every time I start the truck. LoL. Ram Jam… match made in heaven.
Full build log of each upgrade and impressions on wether it is worth, or invest elsewhere.
This is my truck.
Ram All Weather Mats
The mats are a fraction of the cost of Husky or All Weather, they fit like a glove and are heavy duty. Easy to take out and clean/install.
35 Inch Tires
It just doesn’t make sense why 35’s wouldn’t be standard on this truck. In fact I would have bought small fitting 37’s instead of the 35 Falken Wildpeaks I purchased. So decide what’s best for you but with 0 rubbing or mods 35’s should be a priority.
Factory Tonneau Cover
Personally for me a Tonneau cover is a must, because I live in Nova Scotia and we get rain every week… lol. With that being said the soft top is very well built and easy to use. Included in picture is the use of ram box and factory Tonneau cover illustrating the use of both. I took the truck though the car wash, and very little water penetrated the back portion near gate. The cover helps MPG if you are driving highway a lot.
Spray Bed Liner
Makes no sense to offer this as an option make this standard Ram in all trucks.
Thuren Extreme Off-road kit stage2
King 2.5 shocks stainless Steel shafts, Thuren front and back track bar, Thuren springs and mounts. King steering stabilizer.
Ah… there is simply no comparison between this system and stock PW. It’s simply worth every bit if you can swing it. Changes the heavy, squirrely, top heavy leaning truck into a…
Sure footed, washboard mashing, whoop eating, body roll eliminating,control inspiring wants more monster. It’s my most pricey upgrade. Yes it’s worth every penny. The PW is simply a different truck with this system. You will be waiting a year if you order now King is massively behind.
Put some boots on shocks because on Atlantic Coast
Which brings me to the tip of the day.
If you live on the East Coast by the water, get snow and city salts every snow storm. Krown your truck every year. Just do it.
Onward.
S&B Cold Air 75-5133
meh, the gain of 5-10hp and a more aggressive sound? Skip if your skeptical, Buy if you WANT BIG HP GA…ah gains
Magna flow 19200 Exhaust
It’s just amazing. Super happy with this buy. It’s made for this truck imo. Looks awesome, sounds awesome, HorSE POWER GA….Gains. You know I’m looking for any extra horsey’s I can find….
Hood Guard
Guardenthuze#Actent400614
This is my 4th Ram. They have all had chips in the clear-coat that ends up feathering/spreading. End result is having to do the whole hood clear coat again. It’s the bump at beginning of hood. You might get lucky, but probably not.
Pulsar 32453
Turn off mds? hors…HORSEPOWER GAINS! Throttle response so you feel like it’s fast, until you actually wanna go fast and realize stomping the pedal is about the same when it’s 1/3 down?
Yea I bought one.
Front driver and passenger ceramic 30% tint. The perfect % to not be rolling down your window every evening trying to make turns, but still being able to pick your nose with confidence.
Not a bad start for a 75th, with 600 miles.
I guess you guys want pictures since this issssss the internet and all. Photo bomb incoming.
B Mitty
B Mitty
Halifax
6.4L
Thuren, tires, exhaust, tuner, mats
B Mitty
B Mitty
Halifax
6.4L
Tonneau cover, Front Mats, Ceramic tint, Tires, Ram boxes, Spray liner.
B Mitty
B Mitty
Halifax
6.4L
Pulsar, hood protector, cold air
TA-PW
Fort McMurray, Alberta
This is my truck.
35 Inch Tires
Spray Bed Liner
Sure footed, washboard mashing, whoop eating, body roll eliminating,control inspiring wants more monster. It’s my most pricey upgrade. Yes it’s worth every penny. The PW is simply a different truck with this system. You will be waiting a year or more if you order now is massively behind.
Onward.
Hood Guard
Pulsar 32453
Yea I bought one.
What is this Krown you’re talking about? We tons of salt in the winter time here in Alberta, I would like some way to protect the underside.
crazy jerry
WY
sweet. ill probly put a bed cover on my list. been wanting one for a while. becarefull you dont wack the rear driveshaft on the crossmember. to check clearance jack the axle up and put juckstands or large wood blocks under the frame rails and slowly let axle down while watching. another thing to possibly keep a eye on is the joint at tcase and front driveshaft. im not sure what the max angle that new joint can handle. guy down the road has a jeep with that newer joint and he said once he changed suspension he called tom woods for a double cardan jointed shaft. something about that new style joint couldnt handle extreme angle like the double cardan. pw joint may be different but thought i would pass it along
B Mitty
B Mitty
Halifax
6.4L
You da man, thanks Jerry I’ll check it out.
Tinman454
Saskatchewan
Sweet job on the build I will say krown is the bomb. Had a 2002 ram and got it done the first week I had it truck was 8 years old with not a spot of rust on it. They used to warranty the body for life if you had it done from new and never missed a year not sure if they still do that. one thing for sure you have one of the sweetest trucks on the east coast.
Tinman454
Saskatchewan
Also the us navy uses krown on all its vehicles it is transporting on decks of ships . there own study proved that its the best defence against rust.
B Mitty
B Mitty
Halifax
6.4L
Thanks appreciate it!
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
The White Mule...
B Mitty
B Mitty
Halifax
6.4L
Guy spends 14k of top of the line equipment and gets 7 replies… where is everyone!? LOL!?
olyelr
Kewadin MI
I thought they used fluid film
olyelr
Kewadin MI
It could be they use that now this was around 2002 when I was told about it . Point being it’s a very well know product and works very well against rust.
Yea i have heard really good things about krown.
Fergusontd
FTD
Villanova
My 2017 Big Horn, "Buddy"! Not many add on's. Side steps, tonneau cover, bug shield.
motorbreath
TX
2019 Power Wagon
Hemi 6.4L
Awesome. Only things it's missing now are some hard sliders and some dirt on it! :headbang:
B Mitty
B Mitty
Halifax
6.4L
It will for sure be getting dirty haha, it’s a new size for truck for me though, I want to have a solid feel on it before I get up to shenanigans
Skatulaki
Green Cove Springs
5.9 liter 360
I want to know what kind of jobs you all have to expend such money ! So I can get same such job !
I'm doing good just to keep up on maintainence !
2023RamWarlock
