Mygig lockpic and Uconnect
runyet
need a lil help
does the lock pic plug into radio then into uconnect
or does the lockpic plug into Uconnect
Thanks
stimpy433
IOWA
One end to the radio and the other end to the plug that was originally plugged into the radio.
baum
savage, mn
2015 Laramie
Its a simple T-harness. You unplug the harness to the back of the radio and put it inline
R
runyet
well I'm adding the uconnect
baum
savage, mn
2015 Laramie
since you have a 2011. if you are going to add a u-connect why not just add a completely new radio? you will get more functionality then your current with the u-connect and lock pic. and it will sound better.
really your only gaining hands free phone.
R
runyet
my radio
R
runyet
I have that
that was the question I was asking my lockpic is installed and not sure how to connect the U connect
R
runyet
My Options are:
OPTION # 1
Truck harness plugs into lockpic and lockpic plugs into U connect and
U connect plugs into back of radio?
OPTION # 2
Truck harness plugs into U connect and
U connect plugs into lockpic and lockpic plugs into back of radio?
baum
savage, mn
2015 Laramie
sorry i thought you were asking what to get..
The lockpic acts as a t-harness do i dont think it makes a difference, i think it will be a trial and error.
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
I think the Uconnect harness is grey, remove from radio and you just plug it into the Lockpick harness connector and then the lockpick harness will have a connector to go to the radio. The Lockpick is the middleman. The other harness should be white which is all the other radio connections, camera and such.
Uconnect - to lockpick - lockpick to - radio
There is an update for your radio with some improvements and a change to the black screen, Version 50.
