Joizee camper
Since buying my 2014 RAM 2500 a couple of years ago I've always had the smell of antifreeze at the front of the truck. I have crawled all over that 6.4L looking for the leak. It never leaves a puddle on the ground or in the engine compartment anywhere. There's no white residue indicative of a coolant leak. I gave up after I noticed my coolant wasn't really going anywhere, the level stayed constant. Now I have finally noticed a bit of a loss in coolant so back under the hood. I found it!! It's difficult to see but the shaft of the water pump has a super small leak that only presents itself while the pump shaft is turning. I found white residue building up just under the snout of the water pump on the passenger side. It's hard to spot because the aluminum brackets oxidize as a white power and when coolant dries, it dries as a white powder. There just happens to be a bit more white powder down there than there should be. No more warranty so I'll have a shop replace the pump once it's convenient to do so. Once it's done I'll report back to make sure that was it. (pretty sure though). I have about 48,000 on the truck.
