Mystery Vacuum Line Help
Discussion in 'Engine & Performance' started by starfleethero, Jun 12, 2019.
Sponsored By: Moe's Performance
  1. starfleethero
    starfleethero Junior Member
    Oct 19, 2016
    Ram Year:
    2002
    Engine:
    5.9L 4X4
    Hello all,
    I'm working with a 2002 Ram 1500 SLT 5.9L 360
    I need some help identifying a broken line coming out of the "T" junction that connects to the break booster check valve.
    It seemed to go somewhere into the top of the engine bay just above the throttle body (I noticed the line snap when I was reinstalling the air cleaner) but I cannot seem to identify the line or where it goes and whether it is safe to use the truck in the meantime.
    Help is very appreciated :)
  2. Fast69Mopar
    Fast69Mopar Senior Member
    38
    146
    80
    May 10, 2019
    Ram Year:
    Engine:
    Where exactly does the other small black vacuum line attach to? The one going straight down from the "T"
    Is this truck 4WD?
  3. starfleethero
    Oct 19, 2016
    Ram Year:
    2002
    Engine:
    5.9L 4X4
    Yes, it is a 4WD. The line that goes straight down from the T seems to go into this unit (attached picture) that sits under the battery.
  4. Fast69Mopar
    38
    146
    80
    May 10, 2019
    Ram Year:
    Engine:
    That unit you are referring to is the cruise control.
    Check the vacuum ports on the side of the intake manifold below the throttle body. There are a couple of ports on the kegger manifolds.
Share This Page
