Navigation Guidance
mikepol2
Pittsburgh, PA
There is a setting on u connect to save the last radio / entertainment setting. That should do it
Yep the dealer tried that on both the old and new radios but no luck. Tried the nav-specific settings with the nav-only volume but same thing, adjusted to start at 2 but once you restart the truck it’s back at 15.
Dean2
Near Edmonton
You may be able to do it in alfaobd I know you can disable navigation lockout so you can use it while driving, it may prevent it from changing the volume?
Where in Alpha did you find the toggle to disable the navigation lock out while driving? Thanks.
On my 2500 I can adjust the nav volume with the radio volume control while the nav is talking. In mine it seems to hold that setting even after shut down and restart. You may want to check and see if you can adjust the volume the same way, but the nav has to be speaking for it to work.
Justthebutler
BC
2017 Ram 1500 SLT
Where in Alpha did you find the toggle to disable the navigation log out? Thanks. On my 2500 I can adjust the nav volume with the radio volume control while the nav is talking. In mine it seems to hold that setting even after shut doewn and restart.
When I get home later I'll have to check on my laptop and send it to you , I think the guys narrowed it down to certain years; But I cant remember.
