Need advice on audio built....
speeed
Already ordered a fox box for dual 12's, would like to install a pair of BMmkIV but not sure if will works, anybody knows about it?
People from fox acoustics said Alpine type R are the best match, just wondering if anybody can review them....
For the rest of the build, my budget is around 1500 +/-
I hope Audio experts can chime in and give me a good advice
speeed
speeed
About the HU im planning to use a Pioneer that I had from my previous car...
DavidRam
SoCal - Redondo Beach
2012 RCSB
Unfortunately, the Fox Boxes are way too much air volume for the BMs. The BMs need between .5 to .6 cuft, they are showing the enclosures at double that, 1.2. Someone please correct me if I am mistaken...
Read this from the owner of Stereo Integrity:
"Can I put the BMmkIV in a smaller enclosure or a larger enclosure?
Yes you can. However, power handling and/or low frequency extension will be affected. The BMmkIV has been engineered to provide optimum performance in 0.5 ft^3 sealed. Making the enclosure volume significantly smaller than recommended will cause a reduction in low frequency extension. On the other side, making the enclosure volume larger will significantly reduce the power handling of the driver. If you make the enclosure smaller than recommended (0.5 ft^3 sealed), we suggest using an aperiodic membrane such as a ScanSpeak Variovent. Making the enclosure larger will diminish power handling as follows: In 0.75 ft^3 power handling is reduced to 375 watts. In 1 ft^3 the power handling is reduced to 300 watts."
Link: http://stereointegrity.com/product/bm-mk-iv-12-subwoofer/
speeed
speeed
Thanks @davidram
I would like to hear what sub's ppl are using with fox box
DavidRam
2012 RCSB
Fox recommends these subs, hopefully other that have these will chime in soon...
Recommended subs for this box.
ALPINE TYPE R, SWR 1223, SWR 1243 and D2 series
JL Audio 12w6 v1 & v2 "v3 subs will not fit"
Punch P3
Kicker CVX 12
speeed
speeed
Already ordered the Skar's.
Now what about speakers, how's the speakers set up?
One on each door and one in front? What about sizes, or what you guys would recommend?
S
scotts2012ram
Guest
Yea skar is good I'm using there amps got good deal on amps and deal on sundown subs
speeed
speeed
Around 1000 / 1200
Echo42987
EcoDiesel
I wouldn't ever think about running Skars. How are they? Sundown Audio makes great amps and subs. That looks like a nice customer enclosure. I might have to go that route w/ the two 12's. I'll trade out my W7 for a couple W6's.
For a 1000 Focals can be had off of ebay. Also check out 12velectronics.com. They have all the Hybrid audio gear. Which is by far the best.
Etroze86
Grand Forks ND
Sundown actually designed skar's original ivx and vvx sub's and amps are pretty damn good.
Etroze86
Grand Forks ND
For 1k I would look towards dynaudio or hybrid audio as they are both great and can be had with passive xovers.
speeed
speeed
Speakers in from are 6.5? And rear 5?
stevenmicheal
