Need an answer ASAP!!!
2wdoffroader
Ok I'm about to do something crazy, I'm about to put on 38's on my 03' 2wd with a 2" level and 2" spacers. 5.9L engine quad cab but my rear is stock can they fit? Are there any precautions? Any thing to worry about pls let me know ASAP cuz I'm going to shop now.
EJM05
Somers, CT
440 Big Block
Yea uhmmm I don't think 38's will fit.
2wdoffroader
2wdoffroader
Yes? No? Git er dun hell ya! What are u waiting for? Help me what should I do?
2wdoffroader
2wdoffroader
38x13.50r20 there stock 20"s lol will they fit on rim? That's another question!
I have on now 35x12.50r20 so will 13.50 tires fit on stock 20s?
HemiBabe
DFW
All you can do is try... The tires will probably rub when you turn and hit bumps in the road with such a small lift... I would say 35 or 36 is your max but I could be wrong
02Steve15
Connecticut
The rims will fit, but I think you will rub in the front.
EJM05
Somers, CT
440 Big Block
Those will definitely hit. 13.50 may be too wide for a stock rim.
2wdoffroader
2wdoffroader
Its only for the back there's no way they will fit on the front so I'm going 35s in front and 38s in back lol
2wdoffroader
2wdoffroader
This other shop said I might need 2" blocks in the back but the ones he has are for a 4x4 are they transferable to a 2wd?
HemiBabe
DFW
thats gunna look goofy but whatever makes you happy lol
A block is a block... all they do is go on top of your leaf spring... it doesnt matter if it's for a 2wd, 4wd, ford chevy dodge... its just a piece of steel. If you do use blocks, you'll need longer U bolts
EJM05
Somers, CT
440 Big Block
I'm sorry if this sounds mean but that is the dumbest things I heard. The tires look like there is no tread on them. 38 in back and 35 in front?? Why??
rambob
LA/MS
318 5.2l
you can fit some military sized michelins. they are narrower. I think they have 56"s
{facepalm}
2wdoffroader
2wdoffroader
Damn hemi babe how do u kno soo much about trucks?
2wdoffroader
2wdoffroader
I did the leveling kit to get rid of the rake look but I think now Im going back to the rack look
rambob
LA/MS
318 5.2l
actually, to raise the leaf spring, they would go under it.
HemiBabe
DFW
ya under them, my bad... But nevertheless, blocks are all the same its just the material they're made out of. They have el-cheapo kits at Auto Zone but I wouldnt trust those blocks... I'd use some 2" square tubing steel if you're still contemplating on doin it
I know quite a bit from workin on stuff with my other half. He has taught me everythin I know :D
ramhunter9
P-Star Jeep Wrangler
13.50 will not fit on a stock rim. If you put them on you will pop off of the bead and wreck your truck.
And no way without at least a 6" lift and 3" body will you fit 38's
2wdoffroader
2wdoffroader
The rims you see In pictures above are stock rims are they 20x9 or 20x8???
TheM4rxxx
