Need help decoding my build sheet.
XXSNOTRODXX
MI
Hey guys, Purchased my truck almost 3 weeks ago. Going over a few things on the build sheet I got from dodge and curious as to what a few of the things are on it. Overall the truck seems to be pretty well loaded and I am seeing alot of things listed that apparently are pretty saute after features from looking around here on the forums.
Also from my understanding the TRX4 package ended in 2010. My truck was a late 2010 build (Oct 2010) and is title as a 2011. Also from my understandings the TRX4 trucks were two tone paint. However....my truck has the TRX4 decals on the bed and they appear to be factory. I am trying to find out if there is something in the build sheet to look for that may explain this. OR if maybe a dealer slapped oem decals on it when it was new,or if the original owner special ordered the truck this way or what?
I purchased the truck here in MI,but the previous owner (original owner) was from Quebec Canada.
Let me know what you guys think about how well you think it is optioned and also I will highlight/number the areas I am interested in finding out more info on. That way if someone has an answer to one/multiple of my concerns they can simply reply by saying for example "To answer #4......"etc...etc...
Vehicle Description 2011 DODGE RAM SPORT 4X4 1500 QUAD CAB PICKUP
Luxury Group
Sport Group
Monotone Paint
160 Amp Alternator
700 Amp Maintenance Free Battery
Electronic Stability Control
Anti-Lock 4-Wheel Disc Brakes
Highline Door Trim Panel
Front Height Adjust Shoulder Belts
Supplemental Side Air Bags
Advanced Multistage Front Air Bags
Carpet Floor Covering
Front & Rear Floor Mats
Driver/Passenger Assist Handles
Rear Underseat Compartment Storage
Overhead Console w/Garage Dr Opener
Elec Shift On Demand Transfer Case
205MM HD Front Axle
235MM REAR AXLE
(#1. I am assuming these are heavy duty front and rear axles?)
Conventional Differential Frt Axle (#2. what does this mean?)
Tinted Glass Windows
Rear Power Sliding Window
Sun Visors w/Illum Vanity Mirrors
STANDARD EQUIPMENT
1 06/13/15
Passenger Side Sun Visor w/Mirror
Power Heated Mirrors, Fold-Away
Remote Keyless Entry with All-Secure
Sentry Key Theft Deterrent System
Dash Liner Insulation
Floor Tunnel Insulation
Instrument Cluster w/Display Screen
Instr. Panel Color Keyed Bezel
200 KPH Primary Speedometer
Temperature & Compass Gauge
Var Intermittent Windshield Wipers
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Accessory Delay
Power Locks
Pwr Front Windows, 1-Touch,Up & Down
Vehicle Information Center
Traveler/Mini Trip Computer
Rear Dome w/On/Off Switch Lamp
Halogen Quad Headlamps
Automatic Headlamps
Daytime Running Headlamps, High Beam
Fog Lamps
Cargo and CHMSL Lamp
Body Color Front Fascia
Body Color Rear Bumper w/Step Pads
Front License Plate Bracket
Front Wheel Spats (#3. what are these? ** edit ** found answer. apparently they are the plastic trim protectors in the area where mud flaps mount)
Body Color Grille
2 06/13/15
Ram's Head Badge
Rear Wheel Well Liners
Body Color Door Handles
B-Pillar Black out
Rear Wheel Spats (#4. same question as #3** edit ** found answer. apparently they are the plastic trim protectors in the area where mud flaps mount)
Ram 1500 Badge
4X4 Badge
Front Bumper Sight Shields (#5. what are these?)
Dual Rear Exhaust
Engine Block Heater
Speed Control
Deep Water Blue Pearl Coat
SIRIUS Satellite Radio
Power Rack and Pinion Steering
Leather Wrapped Steering Wheel
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
(#6 could this be related to the TRX4 decals? or?)
Front Stabilizer Bar
Rear Stabilizer Bar
Tilt Steering Column
Tire Carrier Winch
Full Size Temporary Use Spare Tire
P275/60R20 OWL All Season Tires
17" Steel Spare Wheel
20X9.0 Aluminum Chrome Clad Wheels
Pickup Box
7 Pin Wiring Harness
Trailer Tow w/4-Pin Connector Wiring
Locking Tailgate
3 06/13/15
Body Color Fuel Filler Door
Instrument Panel Parts Module
Door Parts Module
Front End Parts Module
Tire & Wheel Parts Module
(#7. what are these "modules" )
Build To Canada Mkt. Specifications
GVW Rating - 6700#
Canada Dealer Retail
Zone 22-Canada-Quebec
DS/6322 Vehicle Family (#8. what does this mean)
Four Wheel Drive (4WD)/(4X4)
2011 Vehicle Specifications
Price Class S
6 FT. Cargo Box
Quad Cab
1500 Series
Vehicle Order Tracking
Canada Specifications Label
Quebec Province Code
Leather Trimmed Bucket Seats
Dark Slate
Remote Start and Security Group
Sport Premium Group
Bucket Seats
Ventilated Front Seats
Supp. Side Curtain Frt/Rr Air Bags
Heated Front Seats
OPTIONAL EQUIPMENT
4 06/13/15
Rear 60/40 Split Folding Seat
Folding Flat Load Floor Storage
Urethane Shift Knob
All Automatic Transmissions
5-Spd Automatic 545RFE Transmission
Floor Mount Automatic Shift Lever
3.92 Rear Axle Ratio (#9. best factory gear set you can get for this year/model?)
Anti-Spin Differential Rear Axle (#10, from my understanding this is the LSD rear end and is a great feature to have. correct?)
5.7L V8 HEMI MDS VVT Engine
Rear View Auto Dim Mirror
Auto Dim Exterior Mirror
All Vehicles W/Power Mirrors
Power Sunroof
Air Cond ATC w/Dual Zone Control
115V Auxiliary Power Outlet
Garmin Navigation System
Power Lumbar Adjust
Power 10-Way Drvr & 6-Way Pass Seats
Ash Tray Lamp
Ext. Mirrors w/Supplemental Signals
Exterior Mirrors Courtesy Lamps
Body Color Exterior Mirrors
Security Alarm
Sport Performance Hood
Hemi Badge
Federal Emissions
32 Gallon Fuel Tank
Heavy Duty Transmission Oil Cooler
Exterior Mirrors w/Heating Element
5 06/13/15
Electronically Controlled Throttle
Heated Steering Wheel
Heavy Duty Engine Cooling (#11. does this mean it came with a larger radiator...or?)
Next Generation Engine Controller (#12. what does this mean?)
All Radio Equipped Vehicles
9 Amplified Speakers w/Subwoofer
Fixed Long Mast Antenna
Steering Wheel Mounted Audio Ctrls
6.5" Touchscreen Display
Uconnect 430N CD/DVD/MP3/HDD/NAV
Uconnect Voice Command w/Bluetooth
Audio Jack Input for Mobile Devices
Remote USB Port
Goodyear Brand Tires
All Aluminum Wheels
Center Hub (#13. what are they referring too?)
ParkSense Rear Park Assist System
ParkView(TM) Rear Back-up Camera
Power Adjustable Pedals
Remote Start System
Tip Start
Class IV Receiver Hitch
Tire Pressure Monitoring Display
Trailer Brake Control
Locking Lug Nuts
French/Canadian Language
Spray in Bedliner
40GB Hard Drive w/20GB Available
6 06/13/15
For More Info, Call 888-539-7474
1-Yr. SiriusXM Radio Service
4.5 Additional Gallons of Gas
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
Customer Preferred Package 2TL (#14. what is this?)
Customer Preferred Package 26L (#15. what is this?)
Federal A/C Excise Tax
Special Scheduling Condition III
4X4 Tracking
Warren Truck Assembly Plant
Thanks in advance for all the help everyone. Really appreciate it.
14hemiexpress
6.4l
Good looking truck I can't anwser all your questions but my guess is you have a trx package with all of the HD suspension parts. Question 1 I would say that the front axle only is HD the rear axle is strong enough to not need a upgrade. I have to skip down to question 9 now for a 1/2 ton 4wd the 3.92 is the lowest gear set you can get. #10 anti spin diff is a Limited slip diff, also known as a posi, it's a feature I wanted it keeps power even between bot rear tires. # 11 I'm not 100% sure but I would say it could be a bunch of things could be bigger water pump could be bigger radiator could be bigger fan or a combination of all of the above but either way it's got more cooling power. # 12 I believe the next gen controller is for the fact that the hemi is now a variable valve timing engine and the next gen controller is what controls that. Can't anwser 13 but #14,#15 those are codes for quick order packages. When a dealer what's to order a truck they have codes that mean this truck has these specific options it normally a combination of popular options. I don't know what those specific codes mean.
XXSNOTRODXX
XXSNOTRODXX
MI
Thanks for chiming in.
I have a basic idea at what some of the things might be. The cooling system for example... I understand it has more cooling which is a good thing. I don't however know what they did to improve it over a standard cooling system and it is those differences that I am curious of.
Anyone else that might have an idea at what some of these things are on the build sheet or that has specific details on any of them. Please feel free to chime in. I would love to learn what it all means.
Thanks again!.
Outlander
Montreal, QC
Can't help with your specific questions but when I bought my truck 3 weeks ago my dealer told me that because of the weak Canadian dollar, trucks are being shipped to the US from Canada like hot cakes.
XXSNOTRODXX
XXSNOTRODXX
MI
I was curious as to how/why it would have made its way here to the states. Now that you mention that...seems to make alot of sense.
The dealer said it was a one owner truck (carfax confirmed it). So I am guessing the original owner turned it in as a trade in and then it hit the auction block maybe at which point it landed here in the states. who knows. I got a pretty good deal on it...Can't imagine they made much on it between purchase price and import fees and whatever else they might have had to deal with.
Now if I can just get a better grasp on everything on this build sheet I will feel alot more knowledgeable on what exactly everything means.
I would like to get an original window sticker but from my under standing 2011 is to old and they removed the info from the system at chrylser already and all you can get your hands on is the build sheet data.
XXSNOTRODXX
XXSNOTRODXX
MI
And I knew something was up after purchasing the truck. I found a receipt for gas stuffed in a pocket on the side of the center console and it was all in French. And all of the music on the hard drive radio was in French language aswell. That's when I started digging into the car fax and build sheet and found it was originally from Quebec Canada. Kind of neat knowing the journey it has made.
Outlander
Montreal, QC
I often wondered where traded in vehicles go. I hope my rusty old 2004 Ram 1500 SLT ended up somewhere useful, even if for organ transplants so it can help another truck live.
Started out shopping for used and when I mentioned the lack of stock to the dealer that is when he told me about the cross border shipping.
Funny that the music was still there, in French. I reminded the dealer when he was preparing mine to make sure menu system was in English.
Enjoy your new ride, and put a screwdriver to it ... that is when a new vehicle feels like mine!
Checking the build sheet is a good idea I learned from forums like this. In fact, I went through mine while they were prepping it before I picked it up so I could ask a couple of questions. For example, there is a block heater but I could not find a cord. Tech had to search to find where they tucked it away under a plastic panel!
....and do post a picture. I may be new here, but everyone likes to see the rides we have!
R.L.K.
Bristol , Tn.
Wow your truck is loaded compared to my Tradesman ! Lol envious I am !
XXSNOTRODXX
XXSNOTRODXX
MI
I posted a couple pictures earlier in the thread. And I believe I posted some in a thread when I introduced myself to the forum.
And the menu's on the radio were all in english. Just the actual language the music was in was french.
And yes I have done a few things to the truck already but still have a list of things I want to do to it eventually. Leveling kit is one of them (however I really need to figure out the trx4 stuff before I dive into that as I have heard leveling kits for the trx4's are different than the other trucks). And I am thinking of getting a mufflix kit for it and let the ponies roar lol.
XXSNOTRODXX
XXSNOTRODXX
MI
Thank you, on the plus side....no matter how many or how few features everyones trucks may have......they are all still the best looking trucks out there!
XXSNOTRODXX
XXSNOTRODXX
MI
Been a week since my last post. Bumping to the top to see if anyone can lend any info as to what it all means. thanks
PassivAggressor
I believe most of the things you put are not unique to your truck. I can't answer what some items are like the modules and stuff. For instance the HD shocks, I believe all Hemi trucks have that or at least all of them with the 20" wheels. Every new Ram spec sheet I've seen has it. If you're really curious go to a dealership site and grab some VIN's on there and enter those into the build sheet page. It's interesting to see what's similar and what each truck or any Mopar vehicle has.
HemiXpress
The Heavy Duty Cooling means that your radiator has one extra core in it compared to standard, this something that usually comes with a tow package. The Next Generation Engine Controller is the updated PCM over the previous version, this is the one that took longer to crack. As for the rear gears, 3.92 are good depending what your needs are and the LSD is something to have.
XXSNOTRODXX
XXSNOTRODXX
MI
I need not think about checking the vin of other trucks and comparing side by side with mine. Thanks for the tip. Ill check out dealer inventories of similar trucks with vin#'s posted and see if I can any of the info I am looking for.
XXSNOTRODXX
XXSNOTRODXX
MI
Thanks for the info!.
I probably wont put a lower gear set to use the way it would be best used for. Likely wont be hauling much for trailers. Possibly a small camper from time to time sometime in the future. It is mostly just a daily driver that doesnt see much highway use.
Dodge trucker
Kankakee il
From what I was reading the old TRX package is what became teh "Outdoorsman" package.
Dodge trucker
Kankakee il
even most Tradesmans I looked at (except for one) were "loaded" compared to what I am used to in Dodge trucks. I'd have been fine with crank windows and a rubber mat. I have only seen1 since I have been looking, equipped that way. I was gonna go look at it, til I called and the dealer couldn't give me a straight answer to a simple question.
I did finally get someone sorta honest (if that is possible among sales people) It has 20k less than what I wound up with and (something I really wanted) NOT WHITE!!
Among 3 people I talked to at that stealership I got 2 stories about whether it was a local trade or an auction truck. My next question was gonna be about any sort of service history.
