Need Help determining if its the WIN module
Crackedwick
PA
Hi All,
I am new here and have a 2011 ram sport 1500 with the 5.7. I have been going nuts trying to understand if my issues are with the WIN module or something else. Has anyone experienced these issues? If so could you share your experience? Any help is appreciated.
The issues I am having are:
Fobs dont work to lock unlock or remote start
Sometimes the service 4wd , traction control or other lights will stay on when I start the truck
Sometimes when driving there is no response to the throttle
Sometimes the Key falls out of the ignition
The key will only start the truck if inserted one way. if I put it in the other way it says bad key
it is flat sometimes when i step on the throttle
it surges when driving , even though I have the throttle at the same place the rpms go up and down, like there is a lack of something
RamInfo
Utah
5.7L HEMI
Simple stuff first—have you charged the battery and had it load tested, and had the alternator output tested?
best,
DG
C
Crackedwick
PA
The battery is new and the Alternator reads in range.
