Need help locating a 'switch on' fuse in 2022 Ram
HughS
Looking for 'switch on' fuse in fuse box. I am installing a 2 meter in my 2022 Ram. I will be using a fuse tap to take light power to a relay then to the Radio. I cannot locate a 'switch on' fuse in the fuse box. Any help would be appreciated.
rule18
Admin
Administrator
NY
2017 Rebel
@HughS Welcome to RamForum. I've moved this thread into the 5th Gen section for more views/responses.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
If someone else doesn't chime in I'll try to find it for application but for my HD RAM has supplied circuits to "tap" off of under the underhood fuse block. It has quick release tabs to slide it up and roll it over to expose the wires.
I just don't know for your application what wire to use. It will take a little searching.
woojyee
Nebraska
Hemi 5.7 eTorque
In the fuse box behind the knee buster. F66 is a switch on fuse. Not sure if that's what you're looking for
ANGLICO
Bay Area, CA
6.4 L Hemi
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I bought the grille & tailgate badges at a shop that is about 40 miles inland from the ocean in San Diego
ANGLICO
Bay Area, CA
6.4 L Hemi
I'm putting in a Painless Fuse Block (has relay, 3 constant and 4 switched) under the dash.
I plan on pulling the relay switched power from the brake light pedal wiring. It's 3 amp.
Positive will run back through the firewall to the the battery. It comes with an inline fuse.
For all of you "hobbyist" out there.... I know I could have put this together from scratch, cheaper, but considering the cost of wiring and >>>> time, this is a great value to just "get-er done!"
All I have to do now is fabricate a simple metal bracket for mounting/ground. I like cutting and drilling :cool:
I am very satisfied with the quality of assembly/workmanship and all of the wires are ----> labeled as well as have more than sufficient length. It actually was more/better than I expected. This will make wiring up my Dash Cam, CB, other in-cab stuff.................... easier.
1Popeye
