Need help!!!! Multi cylinder miss fire
Cheer0s666
shawano wi
Hey guys I recently got my 2012 5.7 rebuilt from a rebuilder. Started it up and it drove good the first day but then I went to drive it the next day and it has a miss on 4 6 7 swapped coil packs around checked spark plugs and still the same thing anyone experienced this before?
C
Cheer0s666
shawano wi
Also smells like it’s running rich all injectors were tested and all looked good
EdGs
FL
I'd be going right back to the rebuilder.
If you just got it done, I wouldn't have touched anything on it right away.
Cylinders 4, 6, and 7 are three of the MDS cyinders, along with cylinder 1.
Let us know what they say.
C
Cheer0s666
shawano wi
No? Temps are dropped a lot less after the cats could that cause the misfire? Also noticed injectors are just not firing at certain times
Burla
2010 Hemi Reg Cab 4x4
What fuel pressure on/back of the rail?
C
Cheer0s666
shawano wi
Not sure blows blue smoke though think the clogged cats could cause the miss?
Flip-er
Raleigh, N.C
2013 Big Horn 4x4
Cylinders 4, 6, and 7 are three of the MDS cylinders, along with cylinder 1.
WEll just learned something new
Did not know those cylinders were MDS
BUT then again I am not very tech minded, BUT always good to learn new things, so thank you
C
Cheer0s666
shawano wi
Thought blue smoke means rich you can smell it’s dumping more fuel then needed
C
Cheer0s666
shawano wi
Update got a majority of it fixed replaced cats now it runs good when starts up all injectors fire but then it just randomly shuts off 4 and 6 and starts to miss on those cylinders any help would be appreciated
Sherman Bird
Houston, Texas
Only throwing p0300
"Doctor! I have a splitting headache!".... Is it a brain tumor? Eye strain? stiff neck muscles?
This scenario is THE EXACT correlation of what a P0300 is!
This is, along with the lean/ rich codes, THE MOST misunderstood code in the OBD2 system.
I had a P0300 on a 1998 Chevy Tahoe with the 5.7L "R" engine once that drove other shops AND ME crazy!!!!
The ultimate problem??? There was a passenger side (bank 2) catalytic converter whose heatshield had cracked a weld and rattled like silverware when the engine was revved. Everyone ignored that as insignificant, including me.
Eventually, the noise annoyed me to the point of extreme frustration, So, I raised the truck up on the lift and rewelded the cracked heatshield weld.... The P0300 went away never to return.... to this day. Heck of a lesson, eh? :)
Rufi
Netherlands
2006 & 2014
4.7 & Hemi 5.7
Missfires wiil dump fuel in your new cats and destroy them very rapidly if you keep on driving. Clogged cats are a result, not the cause.
