Need help on centering rear wheels after 2/4 drop
M27
SJ,CA
I recently lowered my truck 2/4 with crown suspension coils and the wheels are noticeably closer to the rear of the wheel wells. Parts installed core4x4 track bar with bell tech relocation bracket,core4x4 upper and lower adjustable control arms, ihc no cut brackets, Viking shocks all installed by a shopBB31166D-7ECD-4796-B1CE-718E1D104E63.jpeg BF2E46FE-DD9D-47BA-B296-1C2B8DA97688.jpeg 07EC46D9-363F-4B28-9F87-9AA4ED12374D.jpeg F529A976-1A5C-4703-AD8C-506B0B4EC624.jpeg
Fast69Mopar
I recently lowered my truck 2/4 with crown suspension coils and the wheels are noticeably closer to the rear of the wheel wells. Parts installed core4x4 track bar with bell tech relocation bracket,core4x4 upper and lower adjustable control arms, ihc no cut brackets, Viking shocks all installed by a shopView attachment 243750 View attachment 243751 View attachment 243752 View attachment 243753
Need to get the truck back on the alignment rack. With the adjustable rear control arms you can pull the axle forward with adjustment$$d9 and then with it being in the alignment rack you can verify that you have the correct thrust angle so the truck doesn't walk sideways in the rear while driving.
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
Here's mine, mines identical to yours except I have not gotten my no cut brackets installed.
Make certain the core 4x4 arms are the exact length of the arms taken off. There's difference in the upper and lower core 4x4 arms.
If they are, then I'd check they installed the no cuts correctly
M
M27
SJ,CA
Updated pic with wheels centered after adjusting the control arms
Bigskyroadglide
Here is mine after installation of the no cut brackets in the rear and the alignment. Appreciate feedback it appears similar to yours, although the numbers are 2 decimal places vs 1.
Reactions: M27
M
M27
SJ,CA
All specs within acceptable range except for caster. Here are the alignment specs from alldataE26F7893-6BE3-4C34-B7F0-A7F036200CB4.jpeg22B3A8DD-5B24-4645-9D83-8BFD25D68DD6.jpeg
