Jason Lundeen
- May 9, 2020
- 3
- 0
- Location
- United States
- 2011
- 4.7 Flex Fuel
I have a 2011 4.7 Flex Fuel V8 Ram 1500 SLT. My truck overheated last week and i had nowhere to pull off to so i made it home but it was running way hot for about 10 mins and then before i could back in the driveway, it was idling very low and eventually cut off. There is a crack in the radiator, i have far bigger issues now. There is a knocking in the motor and it seems to be top end but i still cant figure it out. Sounds like some sort of octane knock but i cant quite tell. I removed the oil pan and took a look at all the bearings (rod/main) and went ahead and replaced those. Some of the rod bearings had some wear and scarring but nothing to be causing that issue. Next i took the valve cover off of where the sound seemed to originate from on the right side and rocker arms and all the valves seem to be in check. Maybe its a ring or a piston issue? Just trying to find out where to go from here, nobody i know has this motor and just looking for some advice.
