Need Solid Information on 35's
Presleysdad
2000 Dodge Ram
Hey guy's I'm new to this forum. I came here hoping to get solid information on an issue I am having. This is my issue, I have a 2000 Ram 1500 Off Road Edition with the stock Off Road rims. I currently have 285/70/17's on the truck now with no rubbing. I have ordered the 2" Leveling kit and I am wanting to put a set of 35's on the truck. I live in a small town with no real off road shop of tire shop. I have gotten mixed answers on if I can put 35's on the stock rims and not rub. Some people say I can sense I have the leveling kit and some say I can not. Please help, Im getting new tires and want 35's
Okiespaniel
Work, Shop, Computer
magnum, 5.9
On 2001 rams there is a lug cast into the steering knuckle for adjustable stops but it isn't drilled and tapped.
If you have a rubbing issue you can drill and tap these lugs for a 3/8 bolt and make your own.
I would strongly recommend you invest in an adustable track bar to recenter your axle under the truck when you install your spacers. You'll move it back and over about 3/4 of an inch.
This may answer your question(s) or lead to more.
http://www.ramforum.com/f58/lift_basics_2nd_gen_4x4_rams-25153/
Edit: I didn't really cover off road Rams here so I'll add that to the initial post. When you add those spacers you'll be liftng your ram about 4 inches over a stock non off road ram. That will give you clearence for a "small" 35 like a 315/75 size tire. A larger 35 like a 35x12.5 will limit your trucks suspension...please read my recomendations I've added to the suspension post.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I am running 295/60/20s (34.6") only rub at full lock. I have a 2.5" leveling kit.
This is with my 285/70/17s and the leveling kit
Davy120
fairchild afb
On my old 01 with 315/70r17 on stock rims I rubbed at full lock with a 6in lift....
A modder is never truly done, he is mearly delayed!
P
Presleysdad
2000 Dodge Ram
This is my truck on 285/70/17's with no leveling kit. Kida hard to see but this kinda shows what room i have with the 285's
Davy120
fairchild afb
That looks like my old truck lol
Davy120
fairchild afb
These are 315/70r17 I think you could fit them honestly
Stangshcky12
Oshkosh, WI
5.9 Cummins
A 315/70/17 will fit but will rub in the same spot with or without a lift
P
Presleysdad
2000 Dodge Ram
Do you have a leveling kit on the truck? or does it just look like the back is higher?
Davy120
fairchild afb
No leveling kit, the driveway is kinda angled downwards. It had about 1.5- 2 inches of rake.
a17ram
