need some creativity from everyone...
09SMOKINHEMI
TEXAS
ok, so maybe i went a little overboard with my purchases, or maybe not! lol, but i bought some Hella Black Magic 500's and a Retro Solutions Economy HID 35W kit, planning on doing some HID Hella's behind the grill.
Then i ran across some LED's that JJ was selling and snagged some of those up as well. (check link below)
http://www.ramforum.com/f96/led_daytime_running_lights_-_interest-26444/
now my dilemma is where to put all of these lights, lol. as mentioned before, i initially planned on putting the Hellas behind the grill, but not sure now where to put everything. Please share your thoughts and ideas to see where all of these will go
Musclemckeester
Houston, TX
n/a
n/a
Black magics will fit on the top part of the grill and the LED running lights could fit in the bottom section.
You could also use the LED ones and mount under your rear bumper for added light when backing up.
09SMOKINHEMI
09SMOKINHEMI
TEXAS
another thought too.... would all 4 fit on the bottom behind the grill? like the 2 hellas in the middle and the LED running lights on the outside?
Musclemckeester
Houston, TX
n/a
n/a
I doubt it, the hellas will take up most of the room. Your best bet would be to have one on top of the other than try to fit them next to each other unless your LED bars are really small.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
the LEDs are pretty small
I think mine are going to go in the tow hook area. take that insert out, dremel out a spot and mount there. :D
Didn't Thor have a write up on here about the hellas and how to mount?
09SMOKINHEMI
09SMOKINHEMI
TEXAS
Yea and that's where I initially thought of mounting the hellas
sent from my Samsung Galaxy S3
09SMOKINHEMI
09SMOKINHEMI
TEXAS
that tow hook area might be a good spot for the led's.... :waytogo:
mattman_13
Do the running lamp deals from jj come as a pair?
I'm wanting to add to my reverse lights
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
yup, they come with:
2 DRL modules (can be used as reverse)
1 harness
2 positap connectors
WhiteExpress
Midland, TX
The DRLs don't have to be mounted horizontally either.
You could mount them vertically some where too.
09SMOKINHEMI
09SMOKINHEMI
TEXAS
Now you're thinking outside the box!
stevenmicheal
