Need some help led reverse pods
curryb15
V8 hemi
So I'm getting ready to install 2 3" led pods for reverse lights. I want to mount them under the truck in the rear but I don't really have any pre existing holes that I can use. So my question is where have people mounted lights to and if need be any tips for drilling through the steel?
curryb15
curryb15
V8 hemi
These are the pods I will be installing any help would be greatly appreciated
Juvenator93
ce79db1002e4570ab867ded532bd8800.jpg273321dc267532ea80427f145dc70c77.jpgI used some 5" L brackets and pre existing holes
Rzrman328
The treeline
Same here...went to lowes and bought some l brackets to fab up a single mount for both my pods.
smoothee
St. John's, NL
Couple of galvanized corner brackets from Home Depot...
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Build some brackets to mount them to the bumper brackets where they connect to the frame. Likely different on my 3500 than on your 1500 but you could likely do something similar. I wanted mine tucked under the truck slightly for a cleaner look.
xrsman
Ontario
3.0 Ecodiesel
I drilled holes into the hitch receiver frame and bolted the lights up there. If I could do it over, I'd do the corner bracket like others in this thread have done. That way they'd be straight, and I'd get a little more output. Wish I had thought of that! Lol
Sent from my SM-G930W8 using Tapatalk
curryb15
curryb15
V8 hemi
Out out still looks really sharp tho!
Solid State
2011 Bighorn
L brackets from home depot, painted flat black
DRkNESS
South Jersey
Oh wow lol am I the only one with theirs installed into my bumper ?
curryb15
curryb15
V8 hemi
Flush mounts look great....... I just didn't have the balls to cut into the bumper
DRkNESS
South Jersey
See since I have an old truck, that doesn't bother me lol. :)
deangtp
I went to Home Depot and bought some cute little joist hangers and modified them slightly, then bolted them on. I made a wire harness that uses battery power only switched on with the reverse lights by a relay.
sbarron
Wasilla, Alaska
Cute like this?
Metal, prefinished.... what's not to like? ;)
deangtp
I mean......that is cute, but it's not a joist hanger. This is what I used. I think I had to cut the over the top ears off so they would sit further down on the frame. Drilled a couple holes. Painted the **** out of everything.
Rzrman328
The treeline
Probably the first and only thread on ramforum that utilizes the word "cute" in three different post.
4 if you count mine.
sbarron
Wasilla, Alaska
I realize they weren't joist hangers, but couldn't pass on your "cute" descriptor.
5 posts now.
Sandbox
Warrenton, VA
SST SO
I plan to add some lights this Spring when the weather warms up. What kind of beam are you guys using? I was thinking a flood would be better than a spot beam. Thoughts?
TheM4rxxx
