avp12304
- Oct 29, 2014
- 40
- 1
- 2005, 2006
- 4.7, 5.9 Cummins
coming home from work today, right as i'm pulling into the driveway, the truck starts idiling like crap seemingly out of nowhere, it almost stalls out, i replaced the air flow sensor, cleaned the throttle body (its a mechanical throttle body but idler valve for it is electric) as best as i could, sprayed a few sprays into the idle passage on the TB but didnt wanna go crazy with it in fear of messing up something electronic on that idler bypass valve.( on the throttle body when the truck is running at idle, with the air box off of it...the air going in is kinda loud, through the idle passage on the throttle body, is this normal?) if i rev the truck up to about 1000 rpm it seems to run just fine but at idle is where im having the problem...any ideas? should i adjust that idler screw for the actual throttle blade? or am i completely on the wrong track here and its an o2 sensor or somethin else all together? cause nothing has seemed to change much... any help is appreciated, thank you! (truck has about 168k miles)
