Need to tap into the brain power
JWA_Two
Richmond, VA
2020 Ram 2500
Recently purchased a 2020 2500. 3rd ram for me. Love this one so far, however, have a situation I’ve never ran into.
It is the night edition with led lamps and the 12 inch connect.
I have turned the daylight running lights off on the Uconnect. I have the turn knob for lights to the off position. However, lights remain on no matter what.
The other unusual thing is that I can not press the fog light button that is part of the turn dial. It behaves as it is disabled.
Am I just a novice and this is usual behavior?
Appreciate any feedback. Thanks!
JWA_Two
JWA_Two
Richmond, VA
2020 Ram 2500
Let’s see if these load
JWA_Two
JWA_Two
Richmond, VA
2020 Ram 2500
The picture that I am pointing to, that fog light on/off button does nothing and it has no depress and bounce out type of feel. It’s hard to Touch if that makes sense (real perfect opportunity for that’s what she said joke)
chopperman1
2018 Rebel
5.7L HEMI
DRL cannot be turned off via your radio on a truck that came with them programed from the factory in the "on" position. You will need something such as AlfaOBD to disable them. Radio feature is for a truck that didn't come from the factory with them "on".
TRK_GANG74
Va, Hampton Roads Area
On these trucks the DRL’s are your low beams. It took me a few weeks to figure it out. The light strips above and below the low beam/high beams stay on regardless of the headlight dial setting. As for the fog light/bed light button one is the fog lights and the other are the lights that illuminate the truck bed. Can’t remember which symbol is which. Press one and go look at the white lights in your 3rd brake to see if they come on when you press either one of the buttons.
JWA_Two
JWA_Two
Richmond, VA
2020 Ram 2500
Thanks for the information. I have the “off” and “on” option on the radio but it doesn’t seem to matter which I select.
Then I have my answer regarding the DRL— I thought they would be the light strips versus the low beam.
Still unable to turn off the fog lights though, are those also part of DRL?
RAM DRVR
Mid left coast - Oregon
CTD
Your fog lights are on in the second picture. Do the turn off when the high beams are on?
Top button fogs, bottom button bed lights.
JWA_Two
JWA_Two
Richmond, VA
2020 Ram 2500
I’ll check in the morning if they turn off with high beams on. The fog light button though does not react when I push it. It doesn’t have any give when I push it like the bed lights button.
KKBB
Oakland Ia
From what I have read it seems as if the DRL are behaving as ram intended them to...they don't shut off. There have been a few posts on here talking about it. I have never tried, just taken people's word on here that it is just the way it is!! The fog lights seem like your switch is jacked up to me...my 2019 you can clearly feel the button depress when you push on it. I always leave my fogs on though, so I never push the button.
runamuck
dfw
6.7 dsl
where on the OBD scanner do you go to turn off DRL
JWA_Two
JWA_Two
Richmond, VA
2020 Ram 2500
Was your truck manufactured for the Canadian market? If my memory serves me, Canadian vehicles are built with DRLs on by Canadian law.
Does not look to be build for Canada. Attached door sticker.
JWA_Two
JWA_Two
Richmond, VA
2020 Ram 2500
Yes, the fog lights turn off when high beams on.
JWA_Two
JWA_Two
Richmond, VA
2020 Ram 2500
This may sound dumb, but... You know the headlight knob needs to be in either running lights or "on" to turn the fogs on during the day, or auto at nighttime. They do not turn function with the knob in the off position.
Yup. I have tried each position and fog lights will only go off if high beams on.
I believe it has to do with the actual fog button being “stuck” in on position since I can’t depress it.
turkeybird56
Central Texas
^^^ DITTO ^^^ FOG lights do not run independently OP, as CHOPPER said. They only work when lights are on.
RamDiver
Marlborough, Ontario, Canada
Not what you're searching for but...
I have a different light selector button with a built-for-Canada truck. There's no off, I push the entire light selector button to enable fog lights, and the cargo light has a separate button below the headlamp selector.
I fixed that fog light dropout feature with AlfaOBD. Just disable the dropout enabled feature. :cool:
When I use the high beams, the ditches are now brightly lit with the (fog) driving lights.
AlfaOBD provides the ability to make changes to the DRL. The default for my truck is the turn signals but I can change that to high beams, low beams or fog lights.
JWA_Two
JWA_Two
Richmond, VA
2020 Ram 2500
My believe is that the light dial is the issue. I’m going to look further into it and will report back.
