new 5.7 hemi issue
whitehemiram
after my other thread (wounded hemi) I tore the top end down replaced lifters, pushrods and rocker shafts it had a broken lifter on #2 cyl.
now it will only start with my foot on the gas it won't idle and the etc (red lightning bolt) is on been at this issue for 4 days frustrated enough to consider selling the other love of my life lol (my wife loves that). help please
RonJon '06
Southern Minnesota
The red lightning bolt means there is a problem with the throttle body. Did you clean it when you had it off? There also might be a procedure to reset it after you have disconnected it.
whitehemiram
whitehemiram
yes i cleaned it and I know now when I did my injectors I did not realize there was a procedure to drain the rails so idk what is wrong now lol
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I would check the cylinder compression, you might have one or more push rods out of place.
whitehemiram
whitehemiram
just did that today at 2000 rpm runs smooth until you let off the gas I am thinking maybe putting the old rocker shafts on
RonJon '06
Southern Minnesota
So it will run but only if you have your foot on the gas pedal? Are you getting any codes? What did you clean the throttle body with?
whitehemiram
whitehemiram
throttle body cleaner does that matter?
RonJon '06
Southern Minnesota
That could be the problem. If you use anything but non-chlorinated brake cleaner and get it on the electronics the the TB might be toast. There are also a couple of procedures posted that tell you how to recalibrate the TB but I'm not sure which one is correct or if it needs recalibrating at all.
whitehemiram
whitehemiram
oops lol I don't think I got it on the electronics but you never know. I also notice when it stalls its smoking out the tb
Redtruck-VA
Virginia
The APPS recalibration is simple enough. After reconnecting the battery, the first time you go to start the engine. Turn the ignition key to the on position without starting the engine and without touching the accelerator pedal. Wait 10 seconds for the PCM to read the APPS value. Turn off the ignition, then start normal.
Harley Harrold
USAF Ret. 36+ years service
Navy Badge Air Force Firefighter
Mississippi
5.7L HEMI
If the throttle body has been changed, cleaned, or reinstalled, the following
procedure must be performed:
a. Disconnect negative battery cable from battery.
Leave cable disconnected for approximately 90
seconds.
b. Reconnect cable to battery.
c. Turn ignition switch ON, but do not crank
engine.
d. Leave ignition switch ON for a minimum of 10
seconds. This will allow PCM to learn throttle
body electrical parameters.
whitehemiram
whitehemiram
ok left the neg cable unplugged over night tried reset procedure still won't run unless my foot is on the gas lightning bolt still on
whitehemiram
whitehemiram
ok here goes again I just pulled both valve covers all pushrods are in place rolled it over everything is moving fine.
first question I torqued my rockers to 23 ft lbs can they be to tight? it calls for 105 in lbs
#2 is there a way to test the tb
is there something I am missing?
thanks again for all the help
was going to order a new tb want to be sure I looked and there is not a used one within a hundred miles from me
Harley Harrold
Mississippi
5.7L HEMI
105 in lbs. divided by 12 = 8.75 ft. lbs. so @23 ft. lbs. I would say yes you have a problem. The valves can't fully close. I would redo the valve torque asap.
whitehemiram
whitehemiram
oh crap I didn't even do the math dodge told me 105 inlbs/ 23 ft lbs
whitehemiram
whitehemiram
so I went out bought a new torque wrench retorqued the rockers shafts. Motor sounds way better still won't idle
Harley Harrold
Mississippi
5.7L HEMI
I sure thought the valve issue would have fixed your idle problem. Maybe someone else on this forum can get it sorted out for you.:uhoh2:
whitehemiram
whitehemiram
me too thanks again. I ordered a tb today mine is fluttering when you crank
