new amp question
Captain McGillycutty
Maumelle, Arkansas
2011 Power Wagon
alright I have two Rockford 10" p2 subs and they are 4ohm and they are bridged together. The shiitty amp I have now cuts out and over heats. I want to buy a new one. I want something that will be good and supply good power. Now I dont know much about audio so that why im here looking for suggestions. Thanks
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
The P2s - are they DVC or SVC? What is the specs on 'em? RMS numbers?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
well......that bites.
They are DVC 4 ohm subs. Which means when they are hooked up together they will produce either a 1ohm load or a 4 ohm load. Not the typical 2ohm that you would normally see.
Maumelle, Arkansas
2011 Power Wagon
well i was thinking of getting some new type r's but idk what I want to look for so put me good setup with a new amp and type r's 10" what ever is good
quietpeen
2021 TRX
Hellcat
what type of enclosure are you putting them in?
quietpeen
2021 TRX
Hellcat
to get the most out of the setup and this is what i've seen Joe recommend many times - a 1000 watt amp.
Now that is what he says to really get that setup to pound. You could get away with a smaller amp and probably still be happy.
stevenmicheal
