New Coilovers with 6 Inch BDS lift
Jwithing
Jwithing
STL
Just an fyi to anybody in the future, according to BDS, they have redesigned the tie rod ends to be pregreased and non servicable. Feeling the boot, there doesn't seem to be much grease in there. I'd probably rather it be greasable.
crazykid1994
Thanks for the info fellas. My original inent was not to level it. I just thought I could with what I bought, so I jacked the truck up 2 inches in the front and checked the clearance. Looks like I should have the clearance and I actually quite liked the look leveled out at that height. From what I was able to measure of the spacer, while on the truck, it looks like it is a little over 4 inches, but I suppose that could be deceiving and I won't know 100% until I take it off.
Since im not seeing anything frim fox for the rams at 6 to 8 inches, it sounds like I should order some 2 inch leveling spacers doe the front just in case. Any recommendations?
No. You cannot stack a 2” leveling spacer above those. Your 6” lift uses a 5” spacer above the current strut. You would have been better off with leveling coilovers like mine. That would have put you at 7-7.5” of front lift. You cannot gain that much lift with those 4-6” lift coilovers. You are already at 6” front lift
Jwithing
Jwithing
STL
Sorry, I'm still a bit confused. I just remeasured and the current oem strut in there and it is 19.5" and 24.5" with the 5" spacer. The 883-06-073 CO's I have are 26.5". So that should raise my front 2", correct? That may not quite be level, but close. With the 883-06-080 that you have, they're 22.5", which would be 27.5" with the 5" spacer.
I'm really just looking for 2 more inches upfront as a possibility. The option to adjust the coilovers 2 inches down, back to my current height, would be ideal.
Why would a 2 inch spacer ontop of the 883-06-073 not work?
Sorry if I'm being dense, something just isn't clicking for me.
My current height from ground to bottom of my bushwhacker fender flares is about 43" in front
crazykid1994
The stock front struts are 22.5” long. My coilovers are stock length at 22.5” but preload for ride height adjustment let’s me go up 2”. Yours are 26.5” so only 4” longer than mine but you can preload them up for 2” more just like I can but your base length is 4” taller than mine. Overall length only tells you where the wheel travel ends. Not actual ride height. Preload adds the 2” more for ride height.
Jwithing
Jwithing
STL
Ok so the ones you have give overall ride height adjustment options of 5.5" to 7.5" when the 5" spacer is included then, correct? Again just want to make sure I can keep the height where it is and use the preload to increase 2" from where it is.
I can spend $100 to send back what I have with no restocking fee and get the 883-06-080. Just want to make sure I don't go to install and am screwed lol.
Still not sure why I can't remove the 5" spacer and use a 2" spacer ontop of the 4" longer coilovers.
crazykid1994
6” extra is to much added down travel and will blow out the CV axles and without the right upper control arms can damage the upper ball joint as well. The coilovers only allow for 4” extra of down travel to maintain stock geometry. You can run 5” extra which is the included spacer in your kit. You could run a small sandwich spacer like I have. Mine is 1/4” thick which gives me about 1/2” extra lift. The diff drop is 4.5”. It’s all in the geometry. Trying to keep everything within stock geometry. That’s the reason bds sells the 4-6” coilovers that you purchased as replacements for the 5” spacer included in the 6” lift. They don’t offer spacers otherwise it pushes the suspension outside of stock geometry s d can cause damage. You can install yours and set them up to 6.5 or 7” but you are beyond the recommended preload. I’m at 2.5” on mine which is actually .5” above recommended.
Jwithing
Jwithing
STL
Ok, so it sounds like the difference is the 5" spacer being 1" taller than the height difference between 883-06-073 and 883-06-080, which will give 7" of ride height with the 5" lift spacer keeping geometry in spec vs. 6". Sounds like that's the easiest way to keep things uncomplicated. I do have the core 4x4 6+" ucas on the way.
Thanks for hanging in there with me. I'll get these sent back and order the same that you've got. Sounds like 2 inches taller is a pipe dream, but I'll take an inch lol.
Jwithing
Jwithing
STL
You can adjust them up higher than 2” but it’s “not recommended”. Like I said though mine are up at 2.5” you could also add something like these. https://motofablifts.com/i-30558239...eqxUm2bouOCBMu8HT0LhBeIkHCWSypxAaAvp_EALw_wcB
I assume you feel ok about all your angles and what not?
Could i just add a one inch spacer with the taller 883-06-073?
I don't fully understand why I can add more spacers with the 883-06-80 but can't add anything with 073.
Jwithing
Jwithing
STL
Wouldn't the 080 with the BDS 5" spacer and the 073 with a 1" spacer be the same ride height?
crazykid1994
Yes. If you can find a 1” spacer I don’t see why it wouldn’t work but I don’t know if any 1” spacers.
Jwithing
Jwithing
STL
So a 1 inch spacer on the top of the 073 would be ok, but not a 2 inch?
crazykid1994
1” would match your existing setup? 2” would put you outside the current geometry? Not sure what part of that you don’t understand. it’s not the lift amount alone that dictates it’s a combination of things. When you add preload the coilover does not get longer. Allowing the droop to extend past the stock droop will destroy cv axles. I have seen first hand what happens to the cv axles when they are flexed past their designed capability.
Jwithing
Jwithing
STL
I got you, thats the part I wasnt thinking about. I certainly trust your knowledge, just trying to see what my options are and if there's an option that doesn't involve sending back what I have. I'll look for a 1 inch spacer and if I can't find it'll, I'll send these back and get the 080.
crazykid1994
I linked you a 1/2” spacer. That would get you to 7” easy. 2.5” preload plus 1/2” from the spacer.
Jwithing
Jwithing
STL
That's for the coilovers you have, right? If I go with the 4 inch longer ones I have, 073, they're an inch shorter overall. Would that mean 073 could use a 1.5 inch spacer, or would the travel for those not work?
crazykid1994
Any more than 1” would probably be too long. Like I was saying the current spacer is 5” so any more than that would be to much. I would honestly give it a try at 7” and see if you like it it’s in the middle of your 6 and 8” of lift. If you end up definitely wanting the 8” you can have someone make you a spacer from a 1/2” or 3/4” plate of steel or aluminum but you’ll need longer bolts to bolt in the coilover if you go that route.
Jwithing
Jwithing
STL
Yeah the 883-06-073 are the same thing, just with the dsc included. I think I'm going to keep these ones and put them in. We'll see how it turns out.
crazykid1994
Try ordering that spacer I linked you. Crank them up to 2.5” lift and use the 1/2” lift spacer up top. 7” lift. Best bet in my opinion. Remember the 1/2” lift spacer is really only 1/4” thick
