schotzky
Okay, so my 1997 Ram 1500 5.9 was failing to start. I had a hunch it was my fuel pump, it would start up after tapping the tank a couple times with a hammer. One day it failed to start so I ordered a Delphi pump and replaced it. In the snow.
So the truck starts up just fine when I get it all back together. Great, except the fuel gauge doesn't work. I go to the gas station and fill it up, boom the gauge goes to full. Except now the truck wont start. Tap on tank with hammer, boom, truck starts.
Get it home. Mess with it more and notice when i start the truck, it revs, almost dies, then evens out.
When I rev RPMs and let off, the truck almost dies, or dies. Then has trouble starting again.
I briefly looked at the wiring and connectors when I had the tank out, 99% positive I got it all connected properly. I also cleaned the tank out with soap and water and dried it pretty well. The pump was an exact match, except it had that stupid 4 Pin connector adapter. Also tried swapping relays around to see if that was bad. Fuses all look good.
Im no expert, but I think it might be electrical and not pump related, perhaps voltage or a bad ground killing the pump? I have a tester, where and what should I look for?
