Dixieduo
Hello from down south..
I have an 02 Ram with the 4.7. My questions are about some of the issues I am having. First is the door locks,,when the drivers door lock is pressed it sounds horrible and then doesn't want to unlock. Would I need to replace the door lock motor or would the door switch do the trick? Second question is,,the truck drove fine last night,but this morning when I tried to start it it has issues. It starts but dies immediately. If I put pressure on the gas pedal it will stay running but as soon as I let off it dies. What could cause this? I have checked the battery and its charged,terminals are tight, has plenty of gas in the tank that is fresh. I am at a loss on these two problems and hope that someone one here will be able to help. Thanks well in advance!
