- Oct 16, 2017
- 429
- 418
- Location
- SE Michigan
- 2015 Ram Laramie 2500 4 X 4
- 6.4L
WHAT’S IN A NAME?
Using the term “ceramic coating,” simply because it is perhaps the most recognized term in the industry. There are many other terms that are used that are essentially referring to the same category of protective chemical. Simply add the word “coating” to any of these: silica-quartz, liquid quartz, glass, SiO2, silicon dioxide, nano, and others. The term “quartz” is often used because the chemistry of coatings utilizes the element that occurs naturally in quartz crystals. The term “glass” is often used because the cured coating is literally a layer of silicon dioxide molecules that is a couple of microns thick (a “micron” is one-millionth of a meter).
Above found on the internet so it must be true
