- Sep 23, 2017
- 5,321
- 7,349
- Location
- So Cal
- 2019 Ram 1500 Classic Bighorn
- 5.7 Hemi
@Ramm5.7 from my research i thought just running the 5 pin would be enough for reverse to work without splicing. I was under the impression most people ran a 4 pin and tapped the white behind the ds tail. Did the 5 pin alone not work?
5 pin works
The issue is the opt-7 bar reverse wire (white) is seperate from the 4 pin connector that is on their wiring. Instructions say to splice reverse light wire at tailight. I didnt want to do that again so cut the end apart( its solid rubber between pins) and use a white wire pin to plug into the 5 pin adapter connector. Splice their white reverse to pin wire I just seperated and heatshrink to seal it.
