Grams
I doubt the cluster unit has been replaced unless it was done by someone OTHER than a dealer… (BTDT) … as the TIPM/PCM will show otherwise and a re-flash by the dealer would reveal that.
The seat cover and brake/accel-pedals are a clue as to actual “drive time” versus a TOAD….but that truck is Not Likely to have been a TOAD as it is too large/heavy for that service.
Meanwhile…. I had a 2012 Ram 1500 (bought it new) which had 205K miles on it and drove like a new truck. I did regular oil and air filter changes using WalMart Supertech mineral oil…never synthetic….and 100K mile spark plugs. Other than tires, batteries, brakes, etc…. it had no other major work on it…tho’ I DID change the rear axle shafts when a right-rear bearing became noisy at 150K miles towing an Airstream trailer with a heavy tongue-weight. (The Ram 1500’s have wheel/axle bearings that run the rollers Directly ON the axle-shaft…no “race” at all… and the failed bearing scored the shaft. The OEM axles were replaced with Yukon axles ($500 ea) because OEM axles were back-ordered. No further problems….and I sometimes towed a heavy boat treailer and a 10K Dump trailer even.
Bottom Line: You stole that truck. Drive it accordingly. Avoid “magic” oils and snake-****… and be realistic about that truck lasting you forever. …. That’s what I THOUGHT I was planning….when the 87-year-old alzheimers man ran the red light and totaled my truck. Insurance settlement was no where NEAR what I Personally Valued that Truck.
